2 AQ 2200d amps strapped @ 1 ohm? - Car Audio Classifieds!
Old 11-06-2013, 06:23 PM
califaplayer707's Avatar
0/11 ssssss237
Default 2 AQ 2200d amps strapped @ 1 ohm?
Is it possible to strap to audioque 2200d amps together at 1 ohm? the manual says for one amp the lowest impedance is 1 ohm but i have mine at 0.5ohm however im curious about the two amps because the lowest impedance when strapped is 2ohms according to the manual
Old 11-06-2013, 06:32 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
it is possible. i have seen people strap amps @ .25 ohms.
what is your box rise? if you have crazy rise you should have no problems at 1ohm strapped.
My game is legit,
Old 11-06-2013, 06:39 PM
0/11 ssssss237
I havent measured box rise. what im worried about the most is having the amps go into protect or have something inside burn up you know
Old 11-06-2013, 08:22 PM
Sykotic101's Avatar
Vanilla Gorilla
0/11 sssssss46
I run my 2200 at 1/2 ohm daily on 4 twelves. It does not get hot or act stupid. Then again, it does not see anything below 12.7v, ever. Only drops that low if sitting still at idle, wide open on the volume. Take heed when it comes to the clipping light, and you should be fine.
4 Fi SSD/Fi BTL soft parts 12s on AQ2200 at .5 daily;
Focal Polyglass comps/Crescendo CZ65s on JL 300/4;
Mechman 240, DieHard Platinum AGM & Optima Blue top, all KK 0 gauge runs and terminals.
SAZ 3000d strapped at 1 Ohm? NESPL General Car Audio Discussion & Questions 5 06-18-2013 06:35 AM
1/4 ohm strapped smfonic1 General Car Audio Discussion & Questions 11 06-02-2013 09:41 AM
Audioque 2200D @ .5 OHM Sneakysh13 General Car Audio Discussion & Questions 3 06-11-2011 04:35 PM
AQ 2200D at .5 ohm my_stealth21 General Car Audio Discussion & Questions 6 11-09-2010 11:19 AM
Will the AP15001D do 1 ohm when strapped? westman995 General Car Audio Discussion & Questions 14 04-26-2010 11:39 AM
