Amp help - Car Audio Classifieds!
Old 11-07-2013, 08:39 AM
0/11 sssssss40
Default Amp help
Hey guys need some help on amp decisions. I am almost through constructing a band pass box for 2 10 inch Fi Q series 10s dual 2. I amp going to run three batteries the starter battery for head unit and two rear batteries for audio and offroad lighting (7 led bars, 3 32 inch and two 12 inch). The rear batteries will be about three foot apart on each side of truck bed with a manual battery disconnect from front battery to charge. Big 3 is done with royal excellence 1/0. I will run a single 1/0 cable to connect to rear batteries(around 10 ft) (ground and power) my alternator is stock 130 amps at idle on a 5.2 v8. I will run 1/0 from one rear battery to inside of cab to a fused power block and ground block under rear seat where the amps will be around 18 inches from blocks. Going to be using TSpec v12 series RCA, grounding blocks, power blocks, and cable from blocks. On these particular setup should i use a single amplifier run at two ohms such as an alpine mrx 240 or would it be wiser or run two amps at 1 ohm such as an Orion xtr 1400.1d. Any other advice or amp recommendations would be great. Thanks
Old 11-07-2013, 09:52 AM
0/11 sssssss40
Btw the subs have the cooling package I am running a superstart platinum agm 34/78 as a starter battery and plan on running two additional for the amps I'm on a moderate budget
Old 11-07-2013, 10:33 AM
0/11 ssss31258
you'll be better off.. and I mean.. WAY better off.. with an AQ1200 run at 0.5 ohms.
Old 11-07-2013, 11:21 AM
0/11 sssssss40
will my electrical be able to handle .5 ohm?
Old 11-07-2013, 11:23 AM
0/11 sssssss40
Also the aq1200 does not show a listing for .5 ohm, as well as being rated at 14.4 volts where as orion is rated as 12.6, also the subs would be getting less than half their power from one aq run at .5 ohms. they are dual 2
Old 11-07-2013, 11:27 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
The aq at .5 ohm will make well wellnover there 1200 watt rating at 1 ohm. Your electrical should be fine to handle the aq at .5. Like sonic said the aq is a way better choice then the orion.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 11-07-2013, 11:35 AM
0/11 ssss31258
aq1200 does 0.5 ohm.. all day every day.
{and that's with only one yellowtop, a 130a alt, OFC 1/0 big 3 and one run of OFC 1/0}
Old 11-07-2013, 11:48 AM
0/11 sssssss40
ok but will the aq be enough to push both subs they are 1500 rms a pop
Old 11-07-2013, 12:02 PM
1loudmonte's Avatar
0/11 sssss2167
If you want that much power then get the aq 2200 and run it at .5
Old 11-07-2013, 12:08 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Are you serious, papasmurf?! Any amp will push those subs. If your looking to max out those drivers, get a bigger amp.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
The Following 2 Users Say Thank You to Boomintahoe For This Useful Post:
1loudmonte (11-07-2013), Austin175 (11-07-2013)
MTX 7500 watt amp vs sundown, cadence & Kicker - Would you consider this amp? old CACO Admin eBay 20 09-11-2013 03:46 PM
WTB/WTT RE XXX 12" & AMP & enclosure TRADE JL 900/5 laneo Wanting to Buy (WTB) 4 11-24-2012 07:31 AM
WHICH IS BETTER? 4 ch amp @ varying ohm loads per channel OR 4 ch amp AND 2ch amp XORstatus General Car Audio Discussion & Questions 5 05-06-2012 08:51 PM
WTB: Wire & accessories for my amp, subs, & big 3 setup fordking Wanting to Buy (WTB) 7 09-11-2011 05:27 PM
WTB HIFONICS, or US amp , or arc audio amp and o gauge amp kit Jesus805 Wanting to Buy (WTB) 12 07-29-2011 02:43 PM
