Kerfs whonkniws about them - Car Audio Classifieds!
Old 11-08-2013, 09:51 PM
0/11 sssss1691
Default Kerfs whonkniws about them
I want to try my hand at making a kerfed port I can't to make 2 bends at a 6" port but is there a method behind the kerf or a formula any help would be greatful
1996 Chevrolet Impala SS
sub stage : 2 12 orion hcca d2
mids and highs stage: nothing yet
Amps:
bass amp: nothing yet
Mids and highs amp :Audison sr5 for now more to come
Old 11-08-2013, 10:04 PM
FLAstrongman's Avatar
0/11 sssss1156
Feedback Score: 21 reviews
not much to it, just practice
Custom box builds for FL:
Refs: diyma-sold to:Mazda3SQ CA.com-traded:matrxx dude CACO- Sold to: Ajax_6154, brandonb1029, TeejayBee, xx-wade-xx, traded with: papito FLSPL- Bought from:98chevySPL, JBLCAMRY, traded with:97montecarlo, thumpenranger
Old 11-08-2013, 10:11 PM
Eric B's Avatar
LowBlowBro
0/11 sssss2140
I made my own calculator in excel to calculate the number of kerf-cuts and spacing, for whatever radius you want. Just don't know how to share it. The formula is out there if you google it though.
The Following User Says Thank You to Eric B For This Useful Post:
JAYARE2007MAG (11-09-2013)
Old 11-09-2013, 07:44 AM
0/11 ssssss247
Kerfing 101 - How to Kerf MDF for your subwoofer enclosure - FULL Detail - Car Audio Fabrication CAF - YouTube
The Following User Says Thank You to dbsupra For This Useful Post:
Old 11-09-2013, 08:11 AM
0/11 sssss1691
Is it possible to do it with birch?? Or only mdf?
Amps:
Old 11-09-2013, 08:23 AM
0/11 ssssss192
You can do it with birch as well!
The Following User Says Thank You to 6thpinned For This Useful Post:
Old 11-09-2013, 09:37 AM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
Birch makes good kerfs. And post up that spreadsheet. I usually just use the 11 cuts method. But bigger ports look kinda skanky.
Old 11-09-2013, 09:40 AM
0/11 sssss1013
If you are using 3/4" wood its 11~12 cuts evenly spaced for a 90 degree bend.
You just have to play around with the depth on some scrap wood until it feels like it will bend easily. To deep and the wood can tear under its own weight, but to shallow and when you try to bend it, it will crack.
Team Sundown
Team XS Power
Old 11-09-2013, 09:42 AM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
Tbh, try on a couple scrap pieces. I use a table saw, raise the blade up almost to the edge of the wood and cut about every 1/8". I actually just eye ball it tbh, make a couple cuts, bend it, and make a couple more till you get it where you want it
This was my first one
Old 11-09-2013, 08:13 PM
0/11 ssssss247
That's the only problem with birch. If you use the normal stuff with voids it can get a little janky. You could fill it with resin and would be pretty solid though. It wouldn't be a huge deal if you were using internal like above but external it can make it a little fragile.
Anyone good with kerfs? need help Buddah_iii General Car Audio Discussion & Questions 3 03-04-2013 06:49 PM
