How hard is installing a re-cone kit? - Car Audio Classifieds!
Old 11-10-2013, 12:36 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Default How hard is installing a re-cone kit?
Specifically on a memphis m3 15" with the kit from fixmyspeaker
Never did one before, don't want to waste the $100 on the kit. Also don't want to waste a ton of $$$ on shipping the motor there and back if it's not too hard to do myself.
What's a typical price for someone to do it for me, in person, if I don't feel up to it?
team graham
Old 11-10-2013, 12:43 AM
Astrophysicist's Avatar
Almost know nothing.
0/11 ssssss683
$50 I'd say. I think one of the hardest things is getting the coil in right. Otherwise you'll have coil rub..
Old 11-10-2013, 12:53 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
I've never actually reconed one myself. Rob aka thorshammer reconed my Aq HD3 15 and he showed me how but i didn't actually work on it. Me and BallzFast on here put my Sundown 18 together and did the recone. It's not too hard.
Old 11-10-2013, 01:02 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
I want to actually do one, but don't want to f it up and waste $100.
How accurate is this video? (first one I found)
I already took it apart. It's just the motor and basket (separate from each other)
How to recone and repair a speaker or woofer with a Pro Parts recone kit - YouTube
team graham
Old 11-10-2013, 01:24 AM
serjr711's Avatar
0/11 sssss2699
Feedback Score: 65 reviews
You can always bring it by my place on a Saturday. I've done about 40 recones in the last year and a half.
The Following User Says Thank You to serjr711 For This Useful Post:
graham (11-10-2013)
Old 11-10-2013, 01:32 AM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
It's not that hard, just make sure the basket is clean and use shims for the coil, index cards work great, it's like building a box, everyone is nervous their first time
Old 11-10-2013, 03:50 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
if I recall this one is the best
Sub recone - YouTube
Most important things is getting the coil centered and using enough glue/right type of glue.
You will be pretty nervous doing it the first time. But after you see how easy it is (if you take your time and do it right) then you will be fine.
EDIT: I don't think he uses the right glues though... You want to CA glue the spider but Goop the surround and dustcap.
EDIT EDIT: and make sure the coil fits tight before you glue.
Current Build:
#60sHereIcome
The Following User Says Thank You to SINTORMAN For This Useful Post:
97_eldo (11-10-2013)
Old 11-10-2013, 07:00 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
i usually charge 35-50 to recone depending on what the person wants done. make sure everything is clean,you pre-fit everything,have all your supplies on hand and take your time. i leave the shims in the recone the whole time while drying and pull them right before glueing the dustcap on.
check out these vids.
How to Recone Subwoofer - YouTube
How To Recone pt 1of 2, Teardown & Prep - YouTube
How To ReCone pt.2 of 2, Install & Assemble - YouTube
My game is legit,
The Following User Says Thank You to BallzFast For This Useful Post:
Old 11-10-2013, 08:07 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Note about ca glue, activator is not hairspray... a mist on the glue from about 10" away is enough...if u use to much, it will look like butt hole
Clean ur landings with acetone (nail polish remover) ...wipe it with acetone, then wipe with a dry cloth
And let it dry for 24 hours after u set it, don't rush it
Old 11-10-2013, 08:28 AM
cerwinvega_fan's Avatar
Loyal Member
0/11 sssss1788
Shouldn't be too hard as long as u have proper tools and equipment
Rockford power hx2 10" drop in re-cone kit needed ranger2339 (Fix My Speaker) 1 05-09-2013 10:49 AM
Installing an alarm/remote start... How hard? thawaxshop General Car Audio Discussion & Questions 37 10-13-2012 10:51 PM
Still looking for a 15" cone kit. scotch03 Wanting to Buy (WTB) 3 05-02-2012 05:41 PM
Re-cone Kit Help 1 Loud Explorer General Car Audio Discussion & Questions 3 07-10-2011 01:19 PM
FI BL 15 W/Free Re-Cone Kit! deepsilencer 15" Subwoofers 12 03-22-2011 04:05 PM
