rca input broke in amp input - Car Audio Classifieds!
Old 11-10-2013, 04:57 PM
0/11 ssssss772
Default rca input broke in amp input
i need help on my ag2200d one of the rca broke off into rca input so how can i get it fixed any advice
Old 11-10-2013, 05:07 PM
massivespl's Avatar
0/11 sssss8409
This happened to my wife's Hifonics amp. The RCA broke of in the spot where u put it in. I just took the back over off and then poked the broken piece through onto the inside of the amp and problem fixed
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 11-10-2013, 05:33 PM
0/11 ssssss772
u was lucky i wasnt i taken cover off but it didnt seem to show any kind of way to do that it has the tiffany style rca inputs
Old 11-10-2013, 05:44 PM
SPLpizzaguy's Avatar
Humbled by CACO
0/11 sssss3111
Feedback Score: 57 reviews
Super glue something to the end and pull it out. I used a sucker stick for a friends that did it.
Sent from my AS740 using Tapatalk 2
4 sa10s
Taramps 8k
4 American Bass VFL 6.5s
Ohio Generator 305 amp alt
4 Vifa Tweets.
Old 11-10-2013, 05:50 PM
0/11 ssssss772
ok i may try that hopefully i dont get superglue in rca input just my luck
Old 11-10-2013, 05:52 PM
Humbled by CACO
0/11 sssss3111
Lol just saturate the tip and you should be good. DON'T try to drop it in the input jack.
4 sa10s
Taramps 8k
4 Vifa Tweets.
Old 11-10-2013, 05:56 PM
0/11 ssssss772
thanks i try it otherwise i have to find a local shop to do it
Old 11-10-2013, 06:19 PM
0/11 ssssss292
get a pin heat it red hot poke it into the plastic of the pin let it cool and slowly pull the pin out. i do this at least once a week at work. hope it helps
The Following User Says Thank You to Deegan2 For This Useful Post:
biglion (11-10-2013)
Old 11-10-2013, 06:21 PM
0/11 ssssss772
i try that also
Input RCA Voltage for AMP/Slave????? jfoodstamp General Car Audio Discussion & Questions 3 08-01-2013 10:51 AM
Amp RCA Input Causing Noise Burkem_10 General Car Audio Discussion & Questions 15 04-08-2013 12:20 PM
What will happen to my amps if rca input is a tad over what the amp calls for???? Mnorwood01 General Car Audio Discussion & Questions 31 12-31-2012 01:38 PM
rca input problem or no output amp questions Bushj311 General Car Audio Discussion & Questions 3 05-15-2011 03:42 PM
1/0 Aluminum Dual Input Amp Blocks, (4) Stinger 1/0 Distro Tee's, KnuKonceptz 18" RCA Drock040687 Wiring, Electrical & Other Installation Equipment 7 02-15-2010 12:12 AM
