ti basket question - Car Audio Classifieds!
Old 11-12-2013, 03:53 PM
0/11 ssssss435
Default ti basket question
I recently took off a ti basket off a 15 I blew. What I was wondering was if this basket could fit the IA death penalty star motor?
Old 11-12-2013, 04:38 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
From what I read in search, the dp has an odd bolt pattern so ud likely have to drill your own in the ti
Take the dp basket, set the base of the basket (motor side) and set in on the ti's base... center it and mark the holes, drill
111brandon111 (11-12-2013)
Old 11-12-2013, 04:41 PM
korn4life's Avatar
0/11 sssss3718
Feedback Score: 25 reviews
Hey I have a question. How do you drill holes in a basket going from the holes in the motor? I was thinking a template but anyone have any better ideas?
Old 11-12-2013, 04:44 PM
Authorized Vendor
0/11 ssss14115
If you don't have the original/a basket that will fit the motor like I described above, you can use a piece of paper, cut a hole where the pole is so it'll sit on the top plate flat and u should be able to see the holes with a little light... or feel for the hole and push thru
basket question BallzFast (Sundown Audio) 4 07-22-2013 12:59 PM
Basket question.... Omegabunny General Car Audio Discussion & Questions 1 09-24-2011 04:38 PM
SA-10 Basket question 03tbls (Sundown Audio) 2 08-24-2011 03:57 PM
Basket question grimreper912003 General Car Audio Discussion & Questions 11 06-07-2009 12:04 PM
