mmats hd4000.1d - Car Audio Classifieds!
Old 10-16-2014, 01:43 PM
crownvicon26's's Avatar
0/11 sssss1882
Default mmats hd4000.1d
Can this amp run daily at .5 ohm? If so, assuming rise is 2-2.5 times nominal load, can this amp clamp 4k wired to .5 ohm? If not, any amps in the 600 range used that can?
Old 10-16-2014, 01:53 PM
72impala's Avatar
0/11 sssss1706
Feedback Score: 68 reviews
No do not run the mmats at .5 unless it is one of their .5 rated amps
2003 6.8L V10 Excursion Limited
2015 MECA STREET 5 WORLD CHAMP
The Following User Says Thank You to 72impala For This Useful Post:
Silver-N-black (10-16-2014)
Old 10-16-2014, 01:59 PM
0/11 sssss1882
Any amps in this price range able to do this? Aq 3500 v2, ab 450.1, Sundown 3500, ddm3b?
Old 10-16-2014, 02:01 PM
massivespl's Avatar
0/11 sssss8409
Aq ab and sundown DD will all run half ohm with good electrical
Tell sonic u will give him 600shipped
Amper Audio 3800.1 $650 shipped
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following User Says Thank You to massivespl For This Useful Post:
Old 10-16-2014, 02:15 PM
0/11 sssss1882
Will any of them do 4k after rise? Found these amp for less than 600 but 600 is the max I want to spend. The cheaper the better. lol.
Old 10-16-2014, 02:46 PM
0/11 sssss1882
Thanks for the help guys, just gonna strap two gp3kd pro's.
Old 10-16-2014, 03:02 PM
72impala's Avatar
0/11 sssss1706
Good choice
Old 10-16-2014, 03:20 PM
massivespl's Avatar
0/11 sssss8409
U gunna strap at half ohm? Cuz that's not a good idea for .25ohm per amp... Just put each sub on a amp at 1ohm instead
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-16-2014, 03:29 PM
0/11 sssss1882
2 dual 2 ohm subs, can either wire to .5 or 2 ohms. Gonna strap the 3k's at 2ohms.
Old 10-16-2014, 03:44 PM
massivespl's Avatar
0/11 sssss8409
I'd rather have one 4500 watt amp at Half ohm.
I just went from one crossfire 8k at half ohm then got another 8k and strapped them at 2ohm and it wasn't as loud. So I went back to 1 amp at half ohm.. So if I was you. One big solid amp at half ohm.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
dr3wzrdroid1 (10-17-2014)
FOR SALE: MMATS Pro Audio HD4000.1 amplifier Pantera Mono Amplifiers 22 07-29-2014 11:51 PM
FS: 2x Mmats HD4000.1's jhg33k Mono Amplifiers 12 05-09-2014 05:18 PM
Mmats hd4000.1 damwhite Mono Amplifiers 21 01-07-2014 10:28 AM
Mmats HD4000.1 R/T Pimp eBay 0 09-07-2013 03:56 PM
[WTB] MMats HD4000.1 Fcabrera Wanting to Buy (WTB) 14 04-01-2013 12:25 AM
