few sub building questions - Car Audio Classifieds!
Old 10-19-2014, 04:25 PM
0/11 sssssss26
Default few sub building questions
Dumb question....I'm looking to build my own sub and I was wondering how the whole spider stacking works? Do you use a spacer and CA glue or just CA glue them together or both. What would either one be best for?
Old 10-19-2014, 04:40 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
if there matching spiders, 90% of the time there stackable and state that there stackable. if they don't set on each other nicely, there likely not stackable. if there 2 different spiders, use a spacer so the spiders do not hit each other but remember spacing them makes them closer to the cone neck. you run a nice bead of ca around the edge to glue them together, clamping and drying when all stacked
not sure what you mean by the last question
The Following 2 Users Say Thank You to Jeffhulbert50 For This Useful Post:
cjvue (10-20-2014), thedeadmau5 (10-19-2014)
Old 10-19-2014, 04:54 PM
0/11 ssssss346
It all just depends
What kinda motor,basket etc etc
Old 10-19-2014, 07:58 PM
0/11 sssssss26
Thanks for the great answers....I understand now.....what's the best baskets to use? The tc sounds ti baskets look the best to me because they have a 10" spider landing, they are really deep and look they would cool the voice coil well....am I right on that?
Old 10-19-2014, 08:08 PM
Authorized Vendor
0/11 ssss14115
benefits of ti baskets-
-more room for forward and rearward travel
-bigger spider landing (8.5" on the 10, 10" on 12/15/18)
-visual aspect for many
using a 12 spoke or 4 spoke-
-smaller 8" landing on all
-less rearward travel room
-less cooling in a few aspects dependent on spacing/venting
-some don't prefer the looks
with a 2.5-3" voice coil, 8" spiders are sufficient for almost any builds (allow about 1.5-2" travel if spaced and spiders allow)
10" landings are nice since they can handle a 4" coil much better and offer bigger spiders so the spider body is not being maxed out under heavy excursion
Old 10-19-2014, 10:07 PM
0/11 sssssss26
Thanks .....I'm really learning a lot.....if I have anymore questions I'll will be direct them toward Mr. Jeff there....lol if you don't mind......
Old 10-19-2014, 10:17 PM
Authorized Vendor
0/11 ssss14115
don't mind at all... subs are my passion
Old 10-19-2014, 11:32 PM
0/11 ssssss346
What kinda motor are u using
Old 10-20-2014, 12:27 PM
0/11 sssssss26
I dont have any parts yet....all I have is my 18" psi recone with a ma audio hardkore motor.....
Old 10-20-2014, 02:12 PM
0/11 sssssss26
When I get around to building a enclosure for it...I'm sure I'll blow it up not too long after....I have a ct sounds 4k and psi said the sub would handle 1800-2000 rms.........right now its a ma audio 15" hk motor with a 6 spoke 18" basket. Psi HD cone and surround. 4x 8" progressive spiders. Dual 2 ohm 3" 4 layer flat aluminum with a 1.6" winding height with triple tinsel leads stitched with direct leads.......My question is once I blow it can I beef it up more by using a ti basket , a couple of 10" spiders, a 8 layer coil with maybe a 2.5" winding height? Or is the ma audio motor not worth working with?
Sub building questions graham General Car Audio Discussion & Questions 4 04-06-2014 10:06 AM
Sub building questions. bombout800 General Car Audio Discussion & Questions 2 09-04-2011 01:21 PM
Questions about building a fart box - Port area? Ronmeister Enclosure Discussion & Design Construction Help 17 03-23-2011 07:43 PM
need help building my first sub extremechevyman67 General Car Audio Discussion & Questions 12 02-13-2011 10:57 AM
Subwoofer building questions Beatdown337 General Car Audio Discussion & Questions 26 10-02-2010 10:11 PM
