anyone ever triple baffle sa 10s? would it choke em out? - Car Audio Classifieds!
Old 10-20-2014, 07:43 PM
0/11 ssssss656
Default anyone ever triple baffle sa 10s? would it choke em out?
Doing 16 sa10s and need to know if its a good idea to triple or quad baffle because the subs are so close that the gaskets are going to touch and there isn't much wood in between each sub. Problem being that the baskets leave a tight opening for the back of the cones to breathe so i dunno if I could go thicker and choke out the subs.I routed the second layer to make the hole taper open a half inch wider than the first layer. Any thoughts?
New build coming soon.
Old 10-20-2014, 07:44 PM
0/11 ssssss656
The 1st later is facing down here
Old 10-20-2014, 09:04 PM
Adding cross bracing between the baffle and the back wall be be much stronger than adding another layer.
Haelmuscle (10-21-2014)
Old 10-20-2014, 09:05 PM
Silver03gt's Avatar
0/11 ssssss687
You have enough room on the baffle for bracing. I would do that instead.
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
Old 10-20-2014, 09:40 PM
0/11 ssssss656
I plan on bracing with some all thread I have and the back wall is tripled already. I'm afraid still that it's enough subs to still move all 5 sheets braced together.
Old 10-20-2014, 09:52 PM
0/11 ssssssss9
How many tens is that?
Old 10-20-2014, 09:53 PM
0/11 ssssssss9
Oops just seen 16 haha very nice
Old 10-21-2014, 01:56 AM
0/11 sssss5305
I would do bracing front to back. I did 15 10's a few months ago and did 9 layer baffle cuz it was about 780#'s of subs. Didn't work out so well, pretty much ZERO back wave even after opening up the back of the cutouts as big as possible...
Old 10-21-2014, 05:56 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
You need a layer for every sub. So you need 16 baffles.
team graham
Old 10-21-2014, 07:14 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
This build should be good....cant wait to see final results. Wall I'm guessing?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
fishing for 4 10s to run trunk baffle brian84corvette Wanting to Buy (WTB) 0 12-30-2013 05:43 PM
IB / trunk baffle = can fit 2 12s or 4 10s brian84corvette General Car Audio Discussion & Questions 1 12-19-2013 02:33 PM
4 9518 choke out!! 2003f150 Car Audio Videos 0 09-06-2013 10:22 AM
Edlebrock 600cfm Electric Choke Carb LoudBlazer Miscellaneous Stuff For Sale 3 11-07-2011 05:41 PM
wtb pap wmd2 10s or other beefy 10s Craig28 Wanting to Buy (WTB) 5 02-09-2011 08:15 PM
