Quick wiring help on 2 subs please. - Car Audio Classifieds!
Old 10-21-2014, 08:01 AM
0/11 ssssss351
Default Quick wiring help on 2 subs please.
Ok I have a DD m3b I am going to be running on 2 Tantric HD 12s that are Dual 1 ohm. I am assuming since the amp has 4 outputs that I series each sub and then run it to the amp.
So I would run a wire from one positive to one negative on one sub and then the other positive and negative goes to the amp. Then repeat on the other sub correct? No need to series them together?
Old 10-21-2014, 08:04 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
What are you wanting to final load to be. 2 dual 1s can do .25, 1, or 4. On the m3b both of the hot's go to the same spot internally and the grounds go to the same spot internally.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 10-21-2014, 08:12 AM
0/11 ssssss351
Im wanting a final ohm load of 1 ohm. If I series one sub, positive to negative and then run the other positive and negative to the amp that gives me 1 ohm correct? I am hoping I do not have to run wires from sub to sub only amp to sub.
Old 10-21-2014, 08:19 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
What amp is it?
This should help.
https://jlaudio.zendesk.com/entries/...iring-Tutorial
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-21-2014, 08:28 AM
0/11 ssssss351
It's a DD m3b. The only confusing part to me is the amp has 4 outputs so its messing with my mind.
mr505's Avatar
0/11 ssssss327
Subwoofer Wiring Diagrams hope this helps
Old 10-21-2014, 08:32 AM
massivespl's Avatar
0/11 sssss8409
The amp is a mono doesn't mater how many speaker terminals it has
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-21-2014, 08:36 AM
0/11 ssssss351
massivespl's Avatar
0/11 sssss8409
Like this
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-21-2014, 08:40 AM
0/11 ssssss351
I understand that, it's just confusing to me. If I take 2 voice coils and series them it doubles the ohm load so a dual 1 ohm sub in series will be a 2 ohm load. If the amp does what I think it will if I take 2 subs in series and run it to the amp that way it will give me a 1 ohm load but I am not sure on it.
quick ? bout battery wiring...need quick answer [email protected] General Car Audio Discussion & Questions 9 09-02-2011 01:32 PM
quick question about wiring cwruck General Car Audio Discussion & Questions 1 10-10-2010 01:05 AM
quick wiring question justin smith General Car Audio Discussion & Questions 3 09-25-2010 11:44 PM
Quick SUB wiring question! andrewtexas123 General Car Audio Discussion & Questions 12 01-25-2010 08:33 AM
quick wiring question hoodulun General Car Audio Discussion & Questions 4 07-27-2009 08:18 AM
