double baffle and flush mount - Car Audio Classifieds!
Old 10-22-2014, 03:43 PM
crownvicon26's's Avatar
0/11 sssss1882
Default double baffle and flush mount
If you have the correct box dimensions for a sub box then you add a double baffle and flush mount a sub, does it change your tuning frequency because of the port exit length being longer? Not really sure if that's understandable. Lol.
Old 10-22-2014, 03:54 PM
tacomaguy1's Avatar
0/11 sssss4401
only going to 3/4" longer (or however thick the wood you use)...not going to be able to notice any difference
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
The Following User Says Thank You to tacomaguy1 For This Useful Post:
crownvicon26's (10-22-2014)
Old 10-22-2014, 03:59 PM
0/11 sssss1882
Using 3/4 inch wood it would make the port length 1.5 inches longer with double baffling and flush mounting. 1.5 wouldn't make a difference? Should I just decrease the port length by 1.5 inches?
Old 10-22-2014, 04:22 PM
It depends on your ratio. If you've got a massive enclosure and a small port that's only 3" long then adding 1.5" is going to change things more than a small box with a 30" port.
On a side (but related) note, I bet if most people with a ported enclosure in their car took an impedance sweep they'd find that they aren't at their calculated tuning based on free-field assumptions.
Old 10-22-2014, 04:33 PM
0/11 sssss1882
From the design the port length is 15.25 inches for a 6 cube net box. Longer port lowers tuning correct? If so that will be fine.
Old 10-22-2014, 05:19 PM
Yes, longer port will lower tuning. Not by much in your case, so don't worry about it.
Old 10-22-2014, 05:25 PM
0/11 sssss1882
Ok. Thanks bro.
Flush mount mdf rings 1loudmonte General Car Audio Discussion & Questions 15 08-25-2013 01:57 AM
need flush mount rings! Nate Futuristic Wanting to Buy (WTB) 10 11-18-2012 04:00 AM
82-92 Camaro HuMount Flush mount MikeSmith0890 Wiring, Electrical & Other Installation Equipment 2 06-10-2011 05:33 PM
Tweeter flush mount cups nismos14 Wanting to Buy (WTB) 3 03-16-2010 11:42 AM
Flush mount ? on1wheel01 Enclosure Discussion & Design Construction Help 9 03-08-2010 05:59 PM
