Bypassing amp filters? - Car Audio Classifieds!
Old 10-22-2014, 08:53 PM
doug118's Avatar
0/11 sssss4674
Default Bypassing amp filters?
I may be overthinking this but not too sure. Is there a way to bypass amp filters? Example; using an amp with no switchable filter and a LP filter of a 200hz max. Is it possible to run particular amp above 200hz?
Old 10-22-2014, 09:10 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
For sub's or...?
I think so. Just don't turn the little dial or leave it as in the "off" position.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-22-2014, 09:23 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
nope. sounds like your trying to run mids on a subwoofer amp.
Old 10-23-2014, 10:42 AM
drunkenwhippeT's Avatar
0/11 sssss1629
if it's max lpf is at 200hz, it's likely that the drive circuit for the class D output section can't switch fast enough to give a clean signal much above that 200 hz.
Old 10-23-2014, 10:51 AM
Agreed. Once you start reaching half of the Nyquist rate you cease to have an a/c waveform. I seriously doubt 200hz is as high as it will theoretically go before getting too close to the switching frequency, but you don't want to remove that filter.
Old 10-23-2014, 10:54 AM
0/11 sssss1629
I guess not the switching frequency's limitation, but more of the circuit that's modulating the duty cycle of the switching. Last amps I looked at were switched at like 32 and 78 khz.
Old 10-23-2014, 11:02 AM
0/11 sssss2429
Feedback Score: 46 reviews
What model amp? People can speculate all day on what they think, but let's try it. I doubt you will see any issue.
Old 10-23-2014, 11:03 AM
doug118's Avatar
0/11 sssss4674
Exactly. Someone said to put the amp on slave mode, then use a line driver as the amps gain but I really don't want to run a line driver
I have an AQ2200 I can try it with but really don't want to destroy my mids trying it
Old 10-23-2014, 11:17 AM
0/11 sssss2429
Ideally you would remove r192 and jumper from there to the junction of r128 and c110. That would eliminate the lpf stuff.
This is for the aq2200.
Old 10-23-2014, 08:52 PM
doug118's Avatar
0/11 sssss4674
So if that's done, that will essentially put the amp on fullpass?
Amplifier filters... KEVGNAR General Car Audio Discussion & Questions 3 12-16-2012 05:01 PM
Bypassing the Bose amp in an 07 Yukon impryder General Car Audio Discussion & Questions 0 03-27-2012 06:42 PM
noise filters burd337 General Car Audio Discussion & Questions 4 09-05-2011 09:23 PM
Subsonic Filters. 350zkid General Car Audio Discussion & Questions 18 06-13-2009 04:56 PM
K&N filters Mojo General Automotive Chat 17 01-15-2009 09:21 PM
