How to secure your wall to your vehicle? - Car Audio Classifieds!
Old 10-25-2014, 07:14 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
Default How to secure your wall to your vehicle?
I'm in the process of building my wall in my 96 blazer ls 2 door!
My question is how do you GUYS brace your box to your vehicle?
For it not to move when you brake/speed up?
"This next song goes out to everyone within a 3 block radius"
100% FeedBack on eBay
Old 10-25-2014, 07:26 PM
Haelmuscle's Avatar
0/11 sssss1819
PL and bolting the false floor to the floor, some use threaded rods and nuts,
Good Luck,
Kindest Regards.
Old 10-25-2014, 07:31 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
Whats pl
Old 10-25-2014, 07:37 PM
doug118's Avatar
0/11 sssss4674
Glue used to build houses
Loctite PL Premium 10 fl. oz. Polyurethane Construction Adhesive-1390595 at The Home Depot
Old 10-25-2014, 07:55 PM
massivespl's Avatar
0/11 sssss8409
Drill a hole threw the bottom of your wall and take out your tie down bolts or seat belt bolts and run a long bolt from inside your wall into the tied own bolt hole or seat belt bolt hole.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following User Says Thank You to massivespl For This Useful Post:
Haelmuscle (10-26-2014)
Old 10-25-2014, 07:57 PM
massivespl's Avatar
0/11 sssss8409
See the bolts on each side. Those were tie down stops and I took the bolts out and bought longer ones and ran them through the wood.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-25-2014, 08:40 PM
Hdorre's Avatar
0/11 ssssss540
I used a combination of PL Premium 8x and (10) 5/8" bolts on the base.. and some PL on the sides.
Old 10-26-2014, 11:40 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
Thanks guys helped a lot.
Old 10-26-2014, 11:59 PM
power-fanatic's Avatar
Stay Off Tha Porch
0/11 ssssss727
My last wall I had a piece of 2" pipe welded to the floor and roof on each side. I then made brackets that were welded to the pipe and screwed to the side of the baffle then I glassed the front of the baffle to the pipe on the front.
Old 10-27-2014, 03:58 PM
03navi's Avatar
Feel The Bass!
0/11 sssss1505
Any other pcs guys trying to get ideas....
how does everyone secure there walls ? massivespl General Car Audio Discussion & Questions 15 10-29-2014 08:49 AM
Style of vehicle for SS 2X18 Wall?? 2deaf Enclosure Discussion & Design Construction Help 8 06-01-2012 07:41 PM
how do you guys secure a wall? headshok General Car Audio Discussion & Questions 7 09-18-2011 11:43 PM
How do you secure your box? doug118 General Car Audio Discussion & Questions 43 08-22-2011 02:28 PM
Is a blow through considered a wall or vehicle mod? 6btdakota General Car Audio Discussion & Questions 5 01-01-2011 12:37 AM
