Hooked my amp up backwards, Fixable? (Pictures) - Car Audio Classifieds!
Old 10-25-2014, 07:48 PM
VolvoWagon's Avatar
0/11 sssssss61
Default Hooked my amp up backwards, Fixable? (Pictures)
So this is my second install and i was hurrying, no real excuses just wasn't paying attention....
It popped my main power wire 200amp fuse. Both the 70Amp fuses on the DSC1500 are fine.
Is it really as simple as replacing this diode and plugging it back in correctly?
Exterior case of Diode reads: 1N5408 under that number is: BL
Old 10-25-2014, 08:04 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
What happens if you hook it up the right way?
The Following User Says Thank You to oslouie For This Useful Post:
massivespl (10-25-2014)
Old 10-25-2014, 09:05 PM
0/11 sssss2429
Feedback Score: 46 reviews
If the diode is open it should be fine. Those diodes are there to protect this issue.
Old 10-25-2014, 09:06 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Lol
We still got some comedians floating around.
(How the hell do u hook an amp backwards?)
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-25-2014, 09:08 PM
0/11 sssss1411
for this reason - i only use red jacket wire for positive and black jacket wire for negative on all of my builds with no exeptions.
Old 10-25-2014, 09:27 PM
VolvoWagon's Avatar
0/11 sssssss61
Yeah..... It was really just a matter of not paying attention and just hooking shit up.
Silver03gt's Avatar
0/11 ssssss687
I was always wandering what would happen if you hooked it up backwards. Now I know.
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
VolvoWagon's Avatar
0/11 sssssss61
main power fuse is blow so im not sure.
Old 10-25-2014, 09:39 PM
VolvoWagon's Avatar
0/11 sssssss61
Well i bent the diode connections so they where completely separated it did change the power/ground continuity dramatically.
I was at .8ohm before now its reading .920 mega ohms. I have no idea what it should be at...
Old 10-26-2014, 06:22 PM
VolvoWagon's Avatar
0/11 sssssss61
I did hook this amp up and it worked fine. The power and ground are now open.
It seems to be working fine other than its not moving the subs as much as i thought. Gain set to 50% on a 30hz test tone pioneer deck with 4v pre outs at volume 45 wasnt moving the sub free air as much as i thought it should. I dont want to deal with repairing or trouble shooting so im selling it for almost half of what i just bought it for.
Alpine cdm-9801 b+ and ground reverse Hooked up. Fixable? graham General Car Audio Discussion & Questions 5 03-04-2013 12:42 PM
Amp smoked when I hooked it/Ever seen this b4? gibsonm21 General Car Audio Discussion & Questions 23 04-15-2011 12:58 AM
so i hooked up my new amp and....... notloudenuff General Car Audio Discussion & Questions 13 05-23-2010 09:59 PM
hooked up everything amp won't turn on gbo559 General Car Audio Discussion & Questions 32 11-20-2009 11:43 PM
How to: Making sure your speakers arent blown/ hooked up backwards SPL Guru Tutorials & Quick References 1 08-04-2008 10:54 PM
