Box mouting DD m3b ok? - Car Audio Classifieds!
Old 10-26-2014, 08:31 AM
0/11 ssssss351
Default Box mouting DD m3b ok?
I don't have much room so a box mount is the most logical choice. Id it going to get to hot sitting flat against the box?
Old 10-26-2014, 08:33 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Probably, use rubber grommets under each foot to help...
Old 10-26-2014, 08:35 AM
0/11 ssssss351
Ha! Good thinking. That makes sense. Thanks. ...
Old 10-26-2014, 01:42 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
I wouldn't risk it for the fact of vibration. if you can find a different spot to mount it, try.
Old 10-26-2014, 02:54 PM
0/11 ssssss351
Im lacking on space so the box is the most logical choice. Using grommets to space it seems like a good idea.
Old 10-26-2014, 02:59 PM
jeffdachef's Avatar
0/11 ssssss440
Do the test first man. Play a song on full blast, put your head directly on the box. If its stiff enough then you are fine to mount the amp on the box. If your head hurts like a mofo after, imagine what the amp would feel.
Old 10-26-2014, 03:43 PM
drunkenwhippeT's Avatar
0/11 sssss1629
Sell me the amp for cheap when it dies? I've never worked on one with broken solder joints from vibration, it'd be a good experience.
Old 10-26-2014, 04:14 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Somebody has a sig somewhat like this as a quote on here. Don't remember who it is but original quoter was by Taylorfade.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
The Following User Says Thank You to Boomintahoe For This Useful Post:
jeffdachef (10-26-2014)
Old 10-26-2014, 04:18 PM
tv550's Avatar
0/11 sssss1658
Feedback Score: 37 reviews
Just use the rubber grommets and you should be fine I've mounted 95% of my amps on boxes and they have never failed.
Old 10-26-2014, 04:47 PM
0/11 ssssss351
Awesome man thanks.
Fs: Dd m3b 72impala Mono Amplifiers 9 09-28-2014 11:34 PM
Sundown SAZ 1500D v.3 mouting to vehicle body? edouble101 (Sundown Audio) 3 03-11-2013 07:19 PM
amp mouting with no feet JAYARE2007MAG General Car Audio Discussion & Questions 25 01-14-2013 03:32 PM
12 sub with mouting depth of 6 or less sonoma Wanting to Buy (WTB) 1 07-13-2010 11:22 PM
