Knu KCA Cable. Do I Need Another Run? - Car Audio Classifieds!
Old 10-27-2014, 01:28 PM
0/11 ssssss201
Default Knu KCA Cable. Do I Need Another Run?
i'm planning on running 2 mb quart dsc2000's strapped at 2.6. i'm also running an mb quart dsc4X125. i currently have 1 run of 0 and 1 run of 4 gauge knu kca cable from the battery under the hood. is another run of 0 gauge necessary? this is for a daily system but i'd rather be safe than sorry. i just hate running cable in my car.
Old 10-27-2014, 03:03 PM
Estimating at the very top of the range, you've got about 4kw at ~80% efficiency and 500w at ~60% efficiency. That's a combined draw of 5,833w. Divided by 14.4v that's about 400A of current, more if your voltage drops. Figure that the 0/1 is good for about 250A and the 4 is good for about 100-125A, for a total of 350-375A capability.
But that's assuming you're running full blast on all channels simultaneously. On music you're going to be well under those numbers. If the wire is fused appropriately the only thing you have to worry about is voltage drop, which may or may not be helped by having another run.
Old 10-27-2014, 03:50 PM
0/11 ssssss201
my electrical is solid enough. i'm planning on using less than 3k anyway.
Knu Kca whos that Wiring, Electrical & Other Installation Equipment 16 07-12-2013 09:29 PM
FS: 50' run of black Knu KCA 0g MopaRBumpiN Wiring, Electrical & Other Installation Equipment 2 11-08-2012 10:10 AM
KNU KCA 1/0 knu 8 gauge and cadence 1/0 jacobB89 Wiring, Electrical & Other Installation Equipment 7 09-25-2012 12:23 AM
who has run knu klmx cable?? fyerbyrd22 General Car Audio Discussion & Questions 8 02-01-2011 07:33 AM
[SOLD]18' run of KNU KCA PhishHead Wiring, Electrical & Other Installation Equipment 19 12-12-2010 09:45 AM
