Sundown-2500 keeps shutting off - Car Audio Classifieds!
Old 10-30-2014, 06:19 PM
usagunandpawn
0/11 sssssss64
Default Sundown-2500 keeps shutting off
I have a Sundown saz-2500d it keeps shutting off at higher volume. I have 4 skar vvx 10 dual 2ohm.The speakers are ran at 1 ohm to the amp. I can listen at medium volume. When I go louder it goes into protect mode.
Also the Power wire is getting a little warm <not burning hot just warm to the touch> at the fuse terminal.
If anyone knows what could be going on please help me out.
Thanks
Old 10-30-2014, 06:31 PM
Nate Futuristic's Avatar
0/11 ssssss768
Feedback Score: 21 reviews
where is the amp grounded?
if sheet metal find a new ground
if battery what is that battery grounded to?
is it used or new?
Old 10-30-2014, 06:32 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
Sounds like a loose connection. Double, triple, and quadruple check the power and ground at every connection. If using a crimp connector and looseness in it will cause heat and a loss of power that could turn off an amp.
Old 10-30-2014, 06:42 PM
usagunandpawn
0/11 sssssss64
Ground for the battery is to the frame. Ground for the amp is to the frame with nice bolts paint has been scraped off.I have a Sundown 100.4 basically on the same ground location It never shuts off.
The amp is used has been fixed by http://www.db-r.com/
usagunandpawn
0/11 sssssss64
I will check for loose ground at the bolt.
Old 10-30-2014, 06:45 PM
0/11 ssssss768
what vehicle? if your in a unibody thats no frame hahahaha
yeah id check grounds try a new lead wire from the bat to the amp or take it out and run it on a test bench
otherwise send it to DB-R for repair/diagnostics
Old 10-30-2014, 06:48 PM
What's voltage at the amp? If the wire is warm near a fuse point you need to pull all of that apart and check the connections. Either a poor crimp/solder, loose bolt, or fuse issue.
Old 10-30-2014, 06:56 PM
drunkenwhippeT's Avatar
0/11 sssss1629
Definitely want to monitor voltage at amp's input, see what it's doing.
Old 10-30-2014, 08:01 PM
corrie3232's Avatar
0/11 ssssss157
Recheck with multi- meter to make sure you're at 1 ohm
Old 10-30-2014, 08:03 PM
sundownz's Avatar
vendor
0/11 ssss11704
The warm power wire is a little concerning; 1/0 wire should not be warm at all with that amplifier.
- Jacob Fuller
- Owner,
The Following User Says Thank You to sundownz For This Useful Post:
Boomintahoe (10-30-2014)
Amp keeps shutting off Jesseland General Car Audio Discussion & Questions 20 02-14-2013 01:38 PM
Comp tomorrow deck shutting off! 99technine General Car Audio Discussion & Questions 11 05-27-2012 01:00 AM
sundown 2500 and dc xl 18 loudcivic Car Audio Videos 3 08-23-2011 08:09 PM
Orion 2500 or sundown 2500? dadydolas General Car Audio Discussion & Questions 9 05-14-2011 05:51 PM
Shutting down DL sites :( cuseikan Off Topic Chat 22 07-14-2010 06:55 AM
