Dumb question but need help! - Car Audio Classifieds!
Old 11-01-2014, 02:28 PM
jmfrb1's Avatar
0/11 ssssss125
Default Dumb question but need help!
So I'm in the middle of finishing up my box and before mounting my sub I realized something. My sub is facing up with a double baffle but is flush mounted...after mouthing the sub how the hell do I take it out when I need to?
Old 11-01-2014, 02:38 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
Flathead screwdriver duh lol.
Old 11-01-2014, 02:50 PM
0/11 ssssss767
To prevent damage to the box or sub use a right angle pick tool and insert it through one of the screw holes and lift till you can get your fingers under the sub.
Old 11-01-2014, 03:34 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
if you used an aero port you could reach in and push up on the sub
Old 11-01-2014, 03:49 PM
0/11 sssssss31
i flush mounted mine and did a roundover bit so with strong fingers I can get grip
Old 11-01-2014, 04:11 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Why would you need to pry the sub up once it's recessed/flush mounted and in place?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 11-01-2014, 04:50 PM
jmfrb1's Avatar
0/11 ssssss125
Haha I thought about those...however I have a tantric HDD so a screw driver will just mess up the box
Old 11-01-2014, 04:51 PM
jmfrb1's Avatar
0/11 ssssss125
This is something I was thinking about. And I'm using a slot port other wise I would just stick my arm through an aero
Old 11-01-2014, 04:54 PM
jmfrb1's Avatar
0/11 ssssss125
The sub+box is a shit load of weight if I need to take it out
Old 11-01-2014, 04:56 PM
0/11 ssssss767
It works great man. I've been installing for 20 years and I've used this method forever. It doesn't matter how heavy the sub is, as long as your strong enough to pull it strait up and hold it there it will work.
I run HDDs currently as well.
probably a dumb question but quick question about pollyfill mattintc10 General Car Audio Discussion & Questions 15 05-05-2012 04:46 PM
Possible Dumb Question? KickerCobalt General Car Audio Discussion & Questions 3 11-09-2010 12:07 AM
dumb question Memphistahoe02 General Car Audio Discussion & Questions 23 02-07-2010 09:09 PM
dumb question Memphistahoe02 General Car Audio Discussion & Questions 4 02-07-2010 06:30 PM
Maybe A Dumb Question But... BassikInstincts General Car Audio Discussion & Questions 4 10-09-2009 08:31 AM
