I suck at decisions. - Car Audio Classifieds!
Old 11-02-2014, 11:16 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Default I suck at decisions.
Need help. Getting new woofers soon and I've been thinking about this for weeks and still am going crazy over it.
I have a Jeep Cherokee and I'm doing a 4th order. Was PLANNING on doing 6 Custom Zv4 12s on 6 Ampere 3800s. Have 4 3800s right now, and I would have to buy 2 more. Subs would have nightshade v2 coils, SPL cone/surround, and SPL spiders. Would be mounted in the back on a single baffle like Jareds box, and they would be in a 4:1 4th order.
Then I got to thinking, I could do 6 Zv3 15s on 6 Ampere 3800s. It's actually significantly cheaper, only trouble is I would have a much smaller ratio. Even if I did 10 cubes sealed (which is a *tad* smaller for 6 15s) I would have 20 ported (so a 2:1).
I KNOW computer programs/models aren't the end all be all, but having said that, when I put both of these setups in there, the 6 12s in the 4:1 are peaking like 6.5db higher than the 6 15s in the smaller ratio... however, the 6 15s are up 3-4db at 30hz.
My goal is LOUD, not super low, just loud and painful. If anyone on here has heard Scott Bowmans truck when he had the Nsv2 15s in it, exactly like that. I'd like to be able to play down to 30 pretty good and destroy everything from 37-50+ , especially stuff in the 40s.
Which should I do? I've been told by several people to stop overthinking it and just do the 12s, but I'm all over. I'm leaning towards the 12s though. Open to other options, but I'm trying to add power (so 5 or 6 amps, not 4) and has to be Sundown. HALP
It's better to keep your mouth shut and give the impression that you're stupid, than to open it, and remove all doubt.
Mistakes are how you learn; try not to learn too much at any one time.
Old 11-03-2014, 02:42 AM
Haelmuscle's Avatar
0/11 sssss1819
If you want to know 1.5cu ft. Net sealed per 15" in Scott Bowman's BEAST and 2.7:1 ratio if that helps!
Anyway 1.5cu ft. Per Zv.3 15" would be almost the same sound as the NSv.2's but a lil' bit peaking lower I mean very lil' difference that is not noticeable, in my opinion the Zv.3 would be better on the meter as well,
Good Luck,
Kindest Regards.
Old 11-03-2014, 03:34 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Do the 15's and use a smaller sealed side.
Done.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 11-03-2014, 07:53 AM
doug118's Avatar
0/11 sssss4674
I'd go the cheaper route and do the 15's. You ask Jared or Derrick what the Zv3 15's can go in as far as sealed boxes goes? I know that's exactly what they use in the Terra because of it's ability to be in such small boxes
Old 11-03-2014, 07:59 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
How about instead of the Zv4 with spl parts you do X12"s with spl parts. Would be cheaper
My game is legit,
Old 11-03-2014, 08:01 AM
doug118's Avatar
0/11 sssss4674
Zv3 15's can go in a box the same size as, if not smaller, than X12's and would be considerably louder
4:1 ratio with 30 cubes would make it 6 cubes sealed and 24 ported. That's definitely not enough for any 15, even Zv3's
Do 9 cubes sealed for the 15's (1.5 each) which will be 2.33:1
Suck it, F3M4!! TaylorFade General Car Audio Discussion & Questions 24 03-21-2011 01:34 PM
Hmmm decisions decisions... get_low General Automotive Chat 20 10-21-2010 06:03 PM
The Vols Suck LivinLoud08 Sports and Fitness 1 10-09-2010 11:56 AM
Fedex can suck it andrewtexas123 Off Topic Chat 10 05-12-2010 05:56 PM
I suck BIG_SUPERMAN72 Off Topic Chat 1 02-06-2010 06:42 PM
