Help deciding on new system - Car Audio Classifieds!
Old 11-11-2014, 10:19 PM
0/11 sssssss77
Default Help deciding on new system
First off I have had a few systems in the past the last being 4 sa-10 with a aq3500.however I recently got a new vehicle. I need some advice for a sub 2k$ build.
Right now I'm looking at the following.
Vehicle:08 Silverado ext cab.
Box: aero port on passenger side for 4 8s
Subs: 4 hds208
Amp: crescendo 3500
Headunit:AVH-X5700BHS
Wiring: knu 1/0 ofc
I'll probably buy a 50ft roll of wire to do big 3 and be easy until I can afford a high output alternator.
What's your guys opinions on this setup. I'll be raising my rear seats 1.5 inches with 2x4 blocks for spacers to give room for a bigger box
Old 11-11-2014, 10:23 PM
Haelmuscle's Avatar
0/11 sssss1819
Seems like a great plan, I think you can get better sub's but more expensive for sure!
Good Luck sir,
Kindest Regards.
Old 11-11-2014, 10:26 PM
0/11 sssssss77
Yeah I want to stay under 2000$ right now I'm looking at 480$ for subs, 780$on amp, 370$ for deck that's 1630$ not counting box material and wiring and the small things like dash trim kit and harness etc. If you have other recommendations please shoot them my way. I'm not set in stone yet.
What would be a good sub upgrade at like 150$per sub?and is that Headunit as good as people say?
Old 11-11-2014, 10:40 PM
Haelmuscle's Avatar
0/11 sssss1819
As far as I know the best bang for the buck is the Pioneer 80PRS, sub's look at Sundown I mean SA/X, you know SA-8 has done a lot of big things and still holding very well,
If you go with SQ sub's I think their 3500.1 would do higher wattage and it has dual inputs some claim that it's power hungry but couldn't find a proof yet,
For wiring do OFC as you know you'd spend time wiring your car so fining a corrosion on your wires would piss you off lol,
Good Luck,
Kindest Regards.
Old 11-11-2014, 10:44 PM
0/11 sssssss77
I want a double din Deck as I've always enjoyed stuffing a flash drive full of music videos and having them play. And I loved my sa10s just the sa8 are 180 a piece and I want to stay 150 or below unless I buy some used pieces
Old 11-11-2014, 10:52 PM
Haelmuscle's Avatar
0/11 sssss1819
You should do the N.E.X. Then,
You can do refurbished SA's sir!
Good Luck,
Kindest Regards.
Old 11-11-2014, 11:01 PM
0/11 sssssss77
What the difference In the bhs vs nex models? Just navigation basically? Because that's like 150$ more than the bhs haha.
Old 11-11-2014, 11:47 PM
Haelmuscle's Avatar
0/11 sssss1819
Lol all I know is I couldn't find anything other than the NEX I mean screen H/U, I think the BHS has no built in crossovers A.K.A. Not active H/U?
If you're good with other lines just do it and make sure you get high output RCA's,
Kindest Regards.
Old 11-12-2014, 12:01 AM
0/11 ssssss226
pioneer makes double dins with 4-5v preouts.
Old 11-12-2014, 09:45 AM
0/11 sssssss77
Yeah the pioneer nex and bhs both have 3 4v outputs
If I can get a skar 3500.1 and 4 skar zvx8v2 subs for 1300$ is that a better setup
Need Help on Deciding What To Use dbsyko09 General Car Audio Discussion & Questions 3 08-11-2011 02:02 AM
Need help on deciding what to do... themgators511 General Car Audio Discussion & Questions 4 12-28-2009 07:54 PM
Need help deciding on what sub(s) to get SQL Monte General Car Audio Discussion & Questions 15 12-17-2009 08:15 PM
Need help deciding strpperpolef150 General Car Audio Discussion & Questions 13 12-15-2009 01:54 PM
need help deciding fatpat1080 Enclosure Discussion & Design Construction Help 14 02-10-2009 11:20 PM
