Lost output after amp swap - Car Audio Classifieds!
Old 11-18-2014, 06:57 PM
hardrock2401's Avatar
0/11 ssssss219
Arrow Lost output after amp swap
My setup before amp swap...
Hdc3 10 on a belva "2000"
Just now did a direct swap with a brand new B2 quota mk3, for some reason the output is just not there. I have double checked everything, ohm at the amp is right, speaker wires are correctly wired at the amp, voltage at the amp is right, rcas are tight. Gain is good bit higher on the B2 than the belva was. I just dont believe that the belva was even close to the same quality and am kind of lost.
2004 Civic Si - K20a2/6spd swap, First gen Fi Q on a Twisted Sounds 1.3k
2015 Veloster turbo 6spd - stock daily driver
1986 Fiero GT - Pride and joy, awaiting a L67 swap
Old 11-18-2014, 06:59 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Master slave switch or rcas on the output instead of input
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 11-18-2014, 07:04 PM
0/11 ssssss219
Just went out to double check that, rcas are connected to the input side and switch is set to master
Old 11-18-2014, 07:09 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
How are you setting gains? By ear, by eye, dmm?
Old 11-18-2014, 07:14 PM
0/11 ssssss219
I've always done it by ear and never had a problem, I have the gain further up than I have ever had in my life on this b2 (about 3/8 up) and still the output isn't there. I really have not gone any higher as I feel a problem lies elsewhere.
Old 11-18-2014, 07:17 PM
oslouie's Avatar
0/11 sssss5073
It might not be convenient but try swapping rca's. You may have damaged a connector while unplugging it?
Old 11-18-2014, 07:20 PM
0/11 ssssss219
The amp is easy to get to right now, I have my seat out (it will be under it for the install). I will try swapping rcas now.
Old 11-18-2014, 07:23 PM
0/11 ssss31255
swap it back {the belva is rated for more power}
maybe the belva's ratings are legit {reminds me of an AQ1200}
4 Ω: 1 x 540
2 Ω: 1 x 900
1 Ω: 1 x 1200
vs the B2 quota;
4 Ω: 1 x 400
2 Ω: 1 x 750
1 Ω: 1 x 1000
Old 11-18-2014, 07:33 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Why'd you swap amps to begin with?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 11-18-2014, 07:38 PM
0/11 ssssss219
Swapped rca's and changed nothing, if anything it was a hair less output.
I swapped them because I wanted a better quality amp, I wasn't expecting it to be audibly louder or anything....just wanted a more solid of an amp.
Anybody swap amp screws? ENVI3D ONE General Car Audio Discussion & Questions 3 03-07-2014 10:07 PM
direct swap of amps and one runs hotter then the other(dc 7.5k & crossfire 8k) massivespl General Car Audio Discussion & Questions 63 06-24-2013 01:25 PM
direct amp drop in swap from bb2400.1 to bc 5500 is quieter help!! lilsoccersully General Car Audio Discussion & Questions 66 05-19-2012 10:13 AM
Server Swap complete - Now we tweak & test old CACO Admin Announcements - Suggestions - Feedback - Support 15 05-16-2011 09:24 PM
136 amp for 90amp alt swap+Big 3 amartin_72 Build Logs 0 03-28-2010 08:21 PM
