is a 4db gain with just sub swap possible - Car Audio Classifieds!
Old 11-26-2014, 12:01 AM
0/11 sssss1381
Default is a 4db gain with just sub swap possible
I saw on Facebook some texas blazer swapped 4dc xl15s dor some new ct sounds sub same ohm loss and amps and gained 4 db in their wall 4th order is that possible
2014 Chevy Silverado lifted 9 inches
Fuel 24x12s and 35s
Nations dual alternator bracket dc power 370 alt, 3 Fi SP4v2 18s,big ass 16v stable amp , JY 45ah 16v Lithium, JY ofc 1/0, fiberglass doors, 3 krome ka10s 3 mclaren mlt8 tweeters. 2 soundigital sd2000.1 evos on mids mclaren 600.2 on tweeters. Pioneer 80prs
Old 11-26-2014, 12:34 AM
0/11 sssssss23
There's a lot of variables but sure anything is possible. He could've had those DC sub's built with stiffer spiders therefore making them less efficient.
Old 11-26-2014, 01:04 AM
0/11 sssss1381
Idk hard to believe when it's same power. I.gained 4db going from 3 600rms subs wired to 1.34 to 3 dc xls wired to .46
Fuel 24x12s and 35s
Old 11-26-2014, 01:12 AM
It's a bit suspect, but if the resonance peaks weren't aligned correctly with the DCs and just happen to be better with the CT's I could see it. He could have also accidentally had something wired in reverse polarity originally, lol.
Old 11-26-2014, 07:03 AM
sundownz's Avatar
vendor
0/11 ssss11704
It's definitely possible if one sub was totally wrong for the application.
Of course -- there could be ALOT more to the 4dB such as a dramatic impedance curve shift (more power) and the new subs mating up the correct FS to the application.
It would be incorrect to assume that others would see similar results if their application isn't the same.
- Jacob Fuller
- Owner,
Old 11-26-2014, 07:23 AM
FLAstrongman's Avatar
0/11 sssss1156
Feedback Score: 21 reviews
I would not believe it unless I saw clamped output from both sub setups.
Custom box builds for FL:
Refs: diyma-sold to:Mazda3SQ CA.com-traded:matrxx dude CACO- Sold to: Ajax_6154, brandonb1029, TeejayBee, xx-wade-xx, traded with: papito FLSPL- Bought from:98chevySPL, JBLCAMRY, traded with:97montecarlo, thumpenranger
Old 11-26-2014, 07:34 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Is it possible? Yes
Is it impossible? No
I'm willing to bet that person took a chance or knew what they were doing.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 11-26-2014, 08:15 AM
mega fatty
0/11 sssss6008
Wasn't it Taylor that did his 15" test
The SA was like 2db louder than any of the bad ass 15's until it reached it's rated power, then the other subs caught up and passed it
If he was under powering the dcs and giving proper power to the cts it's even more believable
Or as said the box was not good for the dcs and really good for the cts
Old 11-26-2014, 08:16 AM
massivespl's Avatar
0/11 sssss8409
Post link to where u seen someone gained 4db
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 11-26-2014, 11:26 AM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
4dbs is a big jump, but not implausible for sure. Say sealed resonance with the dcs was 36hz and ported side was tuned to 46hz, if sealed resonance for the CTs ended up being 46hz when dropped into the existing enclosure then he just go a whole lot of efficiency bump and would have a had a huge gain. CTs might have had lower rise, could be reaching closer to xmax at peak, so many things could cause a huge drop in gain.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
The Following User Says Thank You to e46inperrycounty For This Useful Post:
Haelmuscle (11-26-2014)
To C-pillar wall or not? Gain or no gain sxpimpin General Car Audio Discussion & Questions 7 04-06-2014 04:16 PM
150.4db @ 34hz in S3 - Thanks to Sundown Audio cjvue (Sundown Audio) 7 10-09-2012 01:23 AM
TommyK: 157.4db with 2 12"s e2theloc Car Audio Videos 65 07-13-2012 03:39 PM
HU swap...resetting gain? oslouie General Car Audio Discussion & Questions 7 10-13-2010 10:29 PM
Ridiculous BLAZER -- 153.4db on Termlab sealed w/ 4 12s, NO WALL!! RidiculousSoundz Car Audio Videos 10 09-25-2010 09:57 AM
