1/0 ofc vs cca - Car Audio Classifieds!
Old 11-27-2014, 10:33 PM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
Default 1/0 ofc vs cca
just trying to figure out how important it really is to have ofc ?
see when i first started i went with ofc was not bad running 1 strand of neg and positive from front to rear , but as the build started growing im up to 3 runs of each so i am redoing my amps and need wire again lol.
so im wondering for the short runs 5' or less if a cca will do the job ? i am looking into the 50% blend
Old 11-27-2014, 10:35 PM
FocusOn20s's Avatar
'12 Focus Bangin
0/11 ssssss951
depends on how much current you'll be pulling through the wire. If you're nowhere near the limit of CCA, then you won't notice any difference between the two
If you're stuck between OFC and CCA, you could do welding cable...perks of OFC and pricing of CCA
2012 Ford Focus
Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
Old 11-27-2014, 10:40 PM
caloriu's Avatar
0/11 sssss2863
never used welding cable is it as flexible ?
as for amperage i fuse @ 250 per 5' run . see not much info is given on the limits of the blend but on such short runs 250 amps should be np but idk
72impala's Avatar
0/11 sssss1706
Feedback Score: 68 reviews
CCA rots from Oxidating pretty fast compared to copper. Like way faster. Welding cable is great I use it, just not as flexible. You get what you pay for. Like most other things.
2003 6.8L V10 Excursion Limited
2015 MECA STREET 5 WORLD CHAMP
The Following User Says Thank You to 72impala For This Useful Post:
caloriu (11-27-2014)
Old 11-27-2014, 11:42 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
That's Knu 1/0 cca on the left that was in my last build for over 2 years. Inside the vehicle, no moisture, short runs from batteries to amps. No oxidation
The right is 2/0 flexaprene welding cable.
The Following User Says Thank You to BigBen For This Useful Post:
caloriu (11-28-2014)
Old 11-28-2014, 12:33 AM
Here since Day 1
0/11 ssssss678
Feedback Score: 23 reviews
For a short run cca will be fine.
<<<ME
DO NOT BUY FROM
Trevor Nichols 1499 FM 2109 Huntington, TX 75949
Old 11-28-2014, 03:54 AM
KickinBlazer's Avatar
0/11 sssss1122
with cca you will notice the current transfer isnt as effiecent...and you might have lower voltage at the rear batteries as a result
if its to loud your to old!
Old 11-28-2014, 06:48 AM
doug118's Avatar
0/11 sssss4674
I have cca in my doors, and I have to cut back and restrip the wire anytime we get a really heavy rain. Granted my door leaks a little bit but the wire never gets any actual water on it. It just corrodes super easy. When I redo my doors, I definitely won't be using cca again
Old 11-28-2014, 08:39 AM
72impala's Avatar
0/11 sssss1706
Slice open down the middle of your cca and you will see it is most likely oxidized
Old 11-28-2014, 11:40 AM
BigBen's Avatar
0/11 sssss3006
As asked....
The Following 2 Users Say Thank You to BigBen For This Useful Post:
caloriu (11-28-2014), crownvicon26's (12-02-2014)
1/0 Pure copper OFC & lugs SlaminHo6s Wiring, Electrical & Other Installation Equipment 14 07-25-2013 03:20 PM
Wtt/wts 2/0 PURE Copper kn0wledge000 Car Audio Trader (WTT) 7 05-01-2012 12:11 PM
Pure copper 4 gauge $1 a foot [email protected] Wiring, Electrical & Other Installation Equipment 5 10-26-2011 07:17 AM
Larger CCA vs "Pure Copper" wire upzaw2000 General Car Audio Discussion & Questions 33 09-22-2011 03:42 PM
Hmmm... 2 runs of cca 1/0 or 1 run of pure copper 1/0 87linkin General Car Audio Discussion & Questions 9 09-17-2009 01:44 PM
