How far below tuning do you play? - Car Audio Classifieds!
Old 11-29-2014, 04:35 PM
doug118's Avatar
0/11 sssss4674
Default How far below tuning do you play?
How far below tuning are you willing to play full tilt without worrying about anything? How high? What is your actual tuning and how much port area?
Tuned to 36hz with 9.81" per cube. 25-50hz full tilt before things sound sketchy
Old 11-29-2014, 04:40 PM
0/11 ssssss292
Around the same except im at 32hz tuned. I just use my ear when it sounds janky i back off some.
Old 11-29-2014, 04:47 PM
FocusOn20s's Avatar
'12 Focus Bangin
0/11 ssssss951
2.5 cubes for 1 12 tuned to 30hz, I played down to 23hz full tilt (Sl Jones - Takin Chances) and it did fine. Any lower and it would sound like the sub was bottoming out. Then again, I could've had my SSF set too high aswell.
Not too sure on port area but a 5.5" octoport was used
2012 Ford Focus
Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
Old 11-29-2014, 04:51 PM
0/11 sssss1528
play down to 15hz no problem with the zv4. box tuned at 29hz
Old 11-29-2014, 04:52 PM
doug118's Avatar
0/11 sssss4674
How much port area are you guys using?
Old 11-29-2014, 04:55 PM
I play everything under tuning no matter which box/sub I have in my car. the lowest song I've had was 15hz in the durango tapered tline and sundown sa's
0/11 ssssss292
right around 12 Sq. Per Ft. Its not exact but close.
Old 11-29-2014, 05:02 PM
Haelmuscle's Avatar
0/11 sssss1819
Depends on the sub really, Zv.4 for instance wouldn't be stressed playing below tuning since it has a lot of Xmech, it has 30mm top plate , 65mm coil and a huge tall motor (62.5mm mech clearance)!!!
If you use NSv.2 coil (72mm) in there it would be even beastlier!
You'd reach the mechanical limits at lot higher frequency with the Zv.3 (below tuning) then the Zv.4,
Kindest Regards.
Old 11-29-2014, 05:42 PM
drunkenwhippeT's Avatar
0/11 sssss1629
I don't remember off hand how much port area I have, but my 2 x18s on a saz3500, I play that version of sail that hits 10, 11, and 19 something like that. Tuned at 29hz, 14 ish cubes net. Once with one x18 listening to "bass I love you" I think I heard it bottom, but not sure, only heard it sound like it smacked once. Might have been something in the burban breaking, I dunno.
I love me them lows, tho.
Old 11-29-2014, 05:54 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
2.85cu/ft after sub/port displacement using 2-4" aeros tuned to 30hz and can play down into the 15hz area without worries with the sub i have now going full tilt. If i was still running my DC m2 xl15 then no way lol.
2013 Toyota Highlander
Build to come.....
Anyone play cornhole? King_Corral Off Topic Chat 14 09-17-2012 11:08 PM
My Speakers won't play. sk8nsteven General Car Audio Discussion & Questions 11 07-08-2012 06:01 AM
How do you play with fireworks? Anton Miller Off Topic Chat 10 07-03-2012 07:38 AM
How do you know what hz to play at? Ccab81 General Car Audio Discussion & Questions 15 04-16-2010 11:13 PM
What sports do you play? Patrick Simmons Off Topic Chat 17 08-10-2008 10:24 AM
