AGM under hoods for Civic 92-95 - Car Audio Classifieds!
Old 11-29-2014, 06:06 PM
0/11 ssssss177
Default AGM under hoods for Civic 92-95
I know there are the Shuriken and the XS power.
Has anyone used the Shuriken SK-BT60? I know there is a BT60RT but theres a 40$ difference.
Im only using this front bat to convert over to AGM will be using other bigger AGM batteries in the back.
I will be using a sky high 6 bolt style distro block on the top with stupid amounts off 2/0 so im not sure if I got the BT60 if I would have to space my hood or not. Or if even the BT60RT or the D5100R will be able to do it without having to space the hood. That 2/0 is a tad bit big lol.
Old 11-29-2014, 06:11 PM
doug118's Avatar
0/11 sssss4674
You should have plenty of room under the hood with a stock sized battery
Old 11-29-2014, 07:15 PM
0/11 ssssss177
I see I see. Im just so iffy with those big ol' sky high lugs lol. Its scary.
northstar agm 31 (4) CHRISGIBSON333 Wiring, Electrical & Other Installation Equipment 9 09-01-2014 06:22 AM
2 agm g31 deka intimidators, 4 small agm batts, 2 6" pvc flared ports. with port plug __d_a_v_i_d__ Wiring, Electrical & Other Installation Equipment 15 09-30-2013 02:23 AM
agm battery biglion General Car Audio Discussion & Questions 0 09-09-2012 02:55 PM
Fs: AGM battery luises14 Wiring, Electrical & Other Installation Equipment 2 07-23-2011 01:13 AM
Does anyone have a Honda civic or civic/si 2006-2010 or Audio_Prodigy General Car Audio Discussion & Questions 1 09-17-2010 10:37 AM
