SMD DD-1/Alpine IDA X-200/Hifonics BRZ1700.1D - Car Audio Classifieds!
Old 11-29-2014, 10:01 PM
0/11 ssssss245
Default SMD DD-1/Alpine IDA X-200/Hifonics BRZ1700.1D
Hello
HeadUnit-Alpine IDA X-200 2v F/R/S outs,all at flat settings.
Sub Amp-Hifonics BRZ1700.1D 4ohm unknown 2ohm 1200x1,1ohm 1700x1 for what its worth,its wired at 2ohm 1200x1.
I was using a dd-1 on a friends Alpine IDA X-200 to see where it clipped at ,i used track 1 40Hz -0db,but I couldnt get a reading through the RCA's ,couldnt even get the signal lite to come on the dd-1,let alone read 40Hz or where clipping/distortion was.Why would that be?
So I checked where the HU clipped/distortion. through the amp,using track 1 40Hz -0db and this way it detected the signal,the 40Hz with no clipping/distortion 35/35 volume. Why would it work this way and not the other?
I set the HD at 35,then used track 3 40Hz -5db,it detected signal,then 40Hz and gain was a little less than 3/4 up. Then tried track 5 40Hz -10db,the gain was a little more than 3/4. So i tried track 7 40Hz -15db to get the absolute out the amp,to see where it clipped/distortion, once again it read signal,40Hz but there was no clipped/distortion withe the gain all the way up.Why is that?
Thanks
Old 11-29-2014, 10:37 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
If you read the manual it tells you the last track you used gives you the dirtiest signal but will give you the loudest system. I always use track 5 since it is a compromise.
My game is legit,
Old 11-29-2014, 11:04 PM
0/11 ssssss245
I did read the manuel,i was just curious to why no clipping/distortion at full tilt at 40Hz -15db.
Old 11-29-2014, 11:47 PM
0/11 sssss1528
Where was the gain at?
Old 11-29-2014, 11:58 PM
0/11 ssssss245
all the way up
Old 12-01-2014, 11:33 PM
0/11 ssssss245
could anyone give reasons why it didnt show signal while doing it straight through HU but it did through sub amp?
Hifonics BRZ1700.1 dgaf_ Mono Amplifiers 3 12-13-2014 06:12 PM
Hifonics BRZ1700.1 Lax916 Mono Amplifiers 4 07-30-2014 12:37 PM
Hifonics BRZ1700.1d 06GTMIKE Mono Amplifiers 3 07-01-2013 07:32 AM
Hifonics Brutus BRZ1700.1D andale927 Mono Amplifiers 5 12-23-2012 03:59 PM
Hifonics Brutus BRZ1700.1D or Hifonics HFi2500D teambagboy1 General Car Audio Discussion & Questions 5 05-30-2011 02:11 PM
