thick top plate vs xmax wtf? - Car Audio Classifieds!
Old 11-30-2014, 01:56 AM
0/11 ssss31258
Default thick top plate vs xmax wtf?
somebody has a good excuse..and I want to hear it...
but as I understand xmax is the distance the coil can travel and retain the same number of windings in the thickness of the top plate
0.5 * (ww - top plate thickness)
so, if you have a 1/2" top plate and a 2" ww, the xmax is 3/4"
but if you have a 1 1/2" top plate and a 2" ww, the xmax is 1/4"
Old 11-30-2014, 01:59 AM
Souldrop's Avatar
0/11 sssss1270
edit: too tired to read apparently.
but I would say it has to do with having a larger distance through which you have flux. To counteract the increased top plate you would ideally throw a longer coil in it. That's why overhung, long xmax designs can get so huge. To get the stroke you want you have to increase top plate thickness and then you have to increase coil length to take advantage of that potential throw. At least makes sense in my head... it becomes a balance of flux distance, desired excursion, and desired field strength/lines.
If this sounds crazy, I blame the beer.
Old 11-30-2014, 02:52 AM
Souldrop's Avatar
0/11 sssss1270
I would also assume you want more flux distance to keep lateral cone movement in check.
again my disclaimer of I'm talking out of my ass.
Old 11-30-2014, 03:00 AM
0/11 ssss31258
my goal is simplemaximum xmax.. and maximum P2P..
but I'd like someone to make sense of thick top plate motors since most crazy top plate motors are hailed as impressive/awesome/better
but underhung coils are short ww.. so maybe if you have a 2" top plate and a 1/2" ww, the xmax is 3/4"
and the same # of windings are always in the top plate {the whole coil}
it's just exactly opposite
Old 11-30-2014, 04:04 AM
Haelmuscle's Avatar
0/11 sssss1819
Calling for the GOD Mr. Fuller!!!
Kindest Regards.
Old 11-30-2014, 07:29 AM
sundownz's Avatar
vendor
0/11 ssss11704
The old definition of x-max is "overhang" on an over-hung motor; which decreases as you increase top plate thickness with a given coil -- that is correct.
The modern definition is 70% BL retention.
Your BL curve won't be as linear at the center with a thicker top plate (so distortion will be a bit higher at those levels) -- but your 70% definition won't change much in many instances... AND you *maximum* travel before the coil exits the physical gap increases with a thicker plate (more travel before damage or severe rocking when completely out of the gap).
You can see both changes in these graphs and also the shape of the curve.
As the top plate thickens the 82% BL figure drops -- as the BL isn't as linear in the center... but 70% BL is nearly the same between all three designs because the field is overall bigger so it works out better the farther you go in terms of BL retention.
If we went to 50% BL then you'd see the thickest plate having the highest travel by a good bit. In car audio woofers it's fairly common for folks to push their drivers to 50% BL levels of travel so thickening up the plates is a benefit for those applications.
- Jacob Fuller
- Owner,
The Following 6 Users Say Thank You to sundownz For This Useful Post:
Haelmuscle (11-30-2014), marquez7890 (11-30-2014), RowdyFlat4 (12-04-2014), Souldrop (11-30-2014), SPLEclipse (11-30-2014), ta2ed9783 (12-02-2014)
Old 11-30-2014, 07:35 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Dam. Even Jake is up early on a Sunday!!
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 11-30-2014, 07:40 AM
Haelmuscle's Avatar
0/11 sssss1819
Mr. Fuller you're the MAN
Kindest Regards.
sundownz's Avatar
vendor
0/11 ssss11704
Also as a note... I didn't optimize the design in terms of things like pole extension height, etc as I changed the TP thickness. I only change that one variable for simplicity.
- Jacob Fuller
- Owner,
The Following User Says Thank You to sundownz For This Useful Post:
Old 11-30-2014, 04:04 PM
Souldrop's Avatar
0/11 sssss1270
You really should write a book or have a series of tech threads stickied. Weren't/aren't you working on an underhung Nightshade? That will be cool to see. Of course I'm looking for the optimized BL design you teased a few weeks ago.
3" top plate/back plate for custom motor Jeffhulbert50 Speaker Accessories & Parts 5 11-04-2014 07:52 PM
need my top plate bored out macseven6 General Car Audio Discussion & Questions 74 03-20-2014 06:47 PM
find...that...top plate Jeffhulbert50 General Car Audio Discussion & Questions 24 09-26-2013 10:23 PM
How to realign a top plate bumpin buick Tutorials & Quick References 7 07-15-2013 08:32 AM
Price quote for a adaptor ring for motor top plate to fit a la storm top assembly Brianyakno Toolmaker Price Quote Section 1 04-01-2013 09:39 PM
