Very cold weather and alternator - Car Audio Classifieds!
Old 11-30-2014, 07:00 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Default Very cold weather and alternator
Snowed on Friday and lately it's been very cold here....as low as 18 at night, maybe 30's during the day. Noticed I got quite a bit of alt whine thru my speakers. But, only does this during winter months. Does cold weather have an affect on alts as well as batteries too?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 11-30-2014, 09:27 AM
0/11 sssss1475
Temperature absolutely has an effect on Electron flow, it's odd that it would cause more noise to be introduced though. Batteries require a chemical reaction, heat speeds up that reaction and lack of heat slows it down. The alternator should be running more efficient with the colder weather as heat related resistance is at a minimum. When conductors get hot their resistance increases which creates more heat. Why it's making more noise when cold has me stumped, could it be the brushes are not making as good of contact or regulator running colder than normal? Or something entirely different all together.
On a side note; I have noticed that one of my amps made a buzzing noise during cold weather, from the actual amp not the output of the amp. Once it warmed up from use it would go away.
Old 12-15-2014, 07:41 PM
0/11 ssss12531
It's not an aftermarket alt....so still makes noise sometimes.
Driving me crazy...can't drive around and listen to music while speakers are whining/making noise.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-15-2014, 07:51 PM
Austin175's Avatar
0/11 sssss4224
I've noticed that as well some days it does it some it don't, an my serpentine(spelling) makes this weird noise as well not sure if its because its cold or my belt it 2 sizes smaller then stock.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 12-15-2014, 08:27 PM
0/11 ssss12531
if your belt/pulley on your alt is making a very annoying high pitch squealing once you start your vehicle, it's a lose pulley. Or could be a lose belt too. There's a trick to quiet the belt by putting liquid on it...saw it on youtube.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-15-2014, 08:56 PM
Austin175's Avatar
0/11 sssss4224
No its not alt whine but i do get that when i start it up then goes away, its after i start it up its like a ticking noise an if i push on the gas the ticks get more rapid but its not all the time an just recently started doing it when we got into the colder weather.
(caco),
Kiss my a$$, cold weather Boomintahoe Off Topic Chat 60 12-15-2014 07:55 PM
cold weather and high votage ? Black Toyoda General Car Audio Discussion & Questions 12 02-07-2014 03:51 AM
Hot or cold (weather)??!! Boomintahoe Off Topic Chat 1 05-06-2013 12:50 PM
Deck for cold weather?? soundstream88 General Car Audio Discussion & Questions 11 12-14-2010 07:58 PM
bass and cold weather rawlins87 General Car Audio Discussion & Questions 6 12-02-2010 09:13 AM
