Mixing alt voltages and amperages - Car Audio Classifieds!
Old 11-30-2014, 01:00 PM
0/11 ssssss177
Default Mixing alt voltages and amperages
What happens if i mix alternator amperages? Such as a 220a and a 240a? What if i mix a 240a internally regulated at 14.4 and a stock 70~a at 13.8? Im thinking about having a bracket made for my cs144 singer alt to fit my honda temporary till i can get my honda alt built.
Will the 13.8 charge **** up my cs144 alt charging at 14.4?
Old 11-30-2014, 01:05 PM
massivespl's Avatar
0/11 sssss8409
U will be fine
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 11-30-2014, 01:16 PM
drunkenwhippeT's Avatar
0/11 sssss1629
the 13.8 should pretty much not put out anything till the 14.4 sags down to 13.8.
You could put a diode in line with the sense on the 13.8 alt to raise it's voltage by about .6 volts... I did that with my ad244 that sat at 14.1, brought it up to 14.7. The other alt is a temp compensated regulator set at 14.8. I can't get below 14v at the saz-3500 unless I get well into clipping.
Old 11-30-2014, 02:35 PM
0/11 ssssss177
What type of diode would i need to do this? Im going to be running 2 endo 3500s at a half ohm ea. This is just a little something im trying to do till i can get all of the electrical right as in id prefer to put my money into batts right now instead of an alt because i already have my 240a from my truck.
Old 11-30-2014, 02:42 PM
0/11 sssss1629
I used a rectifier diode salvaged from something, was likely a PC power supply that I had stripped. Basically I went through a pile of salvaged diodes with the multimeter and found one that had .6 volts forward drop. You could probably go to radioshack and get a couple of them for just a few $, as I understand it diodes are commonly 1.2v and 0.6v drop.
Old 11-30-2014, 03:08 PM
0/11 ssssss177
Hiw exactly did you run it to the alt? Ran it inline witg the harness?
Old 11-30-2014, 03:16 PM
0/11 sssss1629
I put it in line with the sense wire on my ad244 4 wire harness (only actually using 2 wires of the 4, the sense and the one that's to a switched 12v) I believe the stripe goes toward the battery.
There's a thread / guide on smd about it, titled something like using diode to raise charging voltage
The Following User Says Thank You to drunkenwhippeT For This Useful Post:
Monkie (12-01-2014)
Old 12-01-2014, 11:37 PM
0/11 ssssss177
Ill be looking into it. Seems pretty easy. Thanks dude
Old 12-02-2014, 02:37 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
6A, 50V Rectifier Diodes (4-Pack) : Diodes | RadioShack.com
Got a radio shack nearby? I've used these before and they work fine.
EDIT: didn't see this mentioned but diodes are polarity sensitive.. so make sure you wire it properly or your alt will go full field..
Current Build:
#60sHereIcome
Old 12-02-2014, 08:12 PM
0/11 ssssss177
Thanks for being specific.
I had a feeling those diodes were what I would need I used them on a past project. I had forgotten that they were directional thanks for the tip. Ill have to try it out.
weird issue with battery voltages phatryan69 General Car Audio Discussion & Questions 5 07-13-2014 08:37 AM
how come gain voltages dont all match on a 4 channel? MERQUE General Car Audio Discussion & Questions 12 03-20-2011 06:52 PM
Load testing voltages of d3100 batts. Violence* General Car Audio Discussion & Questions 68 12-31-2010 10:49 AM
The reason why SD amps performs so well at low and high voltages muriloalvares General Car Audio Discussion & Questions 32 06-19-2010 08:23 PM
Battery Voltages NESPL General Car Audio Discussion & Questions 1 03-18-2010 06:10 PM
