where to mount my amp? (silverado ext cab) - Car Audio Classifieds!
Old 12-03-2014, 11:20 AM
0/11 sssssss77
Default where to mount my amp? (silverado ext cab)
Ok i have an 08 chevy silverado ext cab and need to figure out where to mount my amp. I have a ct4000.1
its too long to fit under the passenger seat lol, too thick to stick on the back wall, not enough room under the seat (already raised my seat 3 inches with custom risers). Im running out of options, I am almost thinking about finding some heavy heavy duty water proof box, and putting the amp in the bed, silicone caulk all the holes for wiring. however thatll look pretty tacky id think.
whats your guys ideas?
Old 12-03-2014, 11:27 AM
0/11 sssss1393
Don't understand how its too think to mount on the back wall but another option is glue a board to your back seat and mount it there, as shafty as it sounds I've seen it done and work fine
Old 12-03-2014, 11:35 AM
0/11 sssssss77
amp is pretty heavy to mount to the seat and wouldnt clear the wall anyways. Have to remember I raised my seats 3 inches which means those little pivot points that stick out in the back are higher up.
heres a picture i took looking straight down the back seat, the little metal bracket when in the closest position to the wall, i have a 2.15inch clearance, the amp being almost 3 inches thick and a piece of plywood itll def be too thick :S
Old 12-03-2014, 05:38 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Extended cab or reg cab??
That pic shows a reg cab...
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-03-2014, 05:39 PM
0/11 sssssss77
It's extended cab. That's my rear set of seats on the back wall
Old 12-03-2014, 05:49 PM
0/11 sssss1393
Have a pic from the side?
Old 12-03-2014, 05:50 PM
Kcbme's Avatar
0/11 ssssss526
Do you have room to make an amp rack in front of the box? I have a full cab so I have a little xtra room but if you did a strait up amp racks vs the slanted one like I have maybe that would work?[IMG][/IMG]
2001 suburban
2.8:1 4th
4 db drive wdx 7k 18s on 2 crossfire 8ks
0/11 sssssss77
Side of? Basically the amp will fit but I can't move the bottom or top of my seat if I need to adjust something. So every time I want to mess with the amp I have to take the whole rear seats out
I'm keeping my rear seats. Otherwise I'd mount it on top of the box lol
Old 12-03-2014, 05:57 PM
0/11 sssss1393
Seats don't move at all? That's tough
Old 12-03-2014, 06:17 PM
andy75's Avatar
0/11 ssssss788
I'm assuming the Sub box is under the rear seat.
02 Silverado Ext. cab build log garren Build Logs 4 06-03-2013 09:59 PM
Silverado Ext Cab Help TampaVmax General Car Audio Discussion & Questions 18 02-18-2013 07:42 PM
94 silverado ext cab rear seat d2freak82 General Car Audio Discussion & Questions 0 11-20-2011 08:30 PM
Ext Cab Silverado Build Caw108 General Car Audio Discussion & Questions 11 03-15-2011 08:28 PM
silverado single cab amp help 1993burban General Car Audio Discussion & Questions 2 03-01-2011 06:13 PM
