how many runs of 1/0 from front battery - Car Audio Classifieds!
Old 12-03-2014, 05:43 PM
0/11 ssssss118
Default how many runs of 1/0 from front battery
i running about 7k rms total for bass and mids. i have a d3400 up front and 2 d3100s in the back.
Old 12-03-2014, 06:22 PM
Sencheezy's Avatar
0/11 ssssss483
You would be fine with a single run of both pos and neg 1/0. Overkill would be 2 runs of each.
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
Old 12-03-2014, 06:36 PM
72impala's Avatar
0/11 sssss1706
Feedback Score: 68 reviews
All you need to do is get your alternator charging the rear bank. Do a single run of 2/0 welding or something like that. I do a single run of 4/0 front to rear, and I only have a 320amp alt so I don't really need it. Your multiple runs go from your battery bank into your amps. If your battery bank is rear, do as many runs as you desire from rear bank to amps
2003 6.8L V10 Excursion Limited
2015 MECA STREET 5 WORLD CHAMP
Old 12-03-2014, 06:39 PM
0/11 ssssss378
id say at least 2 runs with 7k of power isn't 1/0 only good for like 300-350 amps
illinois4life
Old 12-03-2014, 06:48 PM
Depending on your alternator and sustained current draw from the amp, it's possible that you could draw several hundred amps from the front battery. If all of your batteries were in the back you're limited by the current output of the alternator so you don't nave to worry about exceeding that number.
You'll probably be fine with a single run, but make sure voltage stays above the resting voltage of the batteries and fuse the wire appropriately. If you happen to have enough wire to do an extra run or it's not that big of a deal to do so, add another run. You won't need more than two though.
Old 12-03-2014, 07:29 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Heh, overkill.
Rather be safe than sorry. Do it right the 1st time.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-03-2014, 07:38 PM
0/11 ssssss118
what would happen if i have more runs of wire than necessary
Old 12-03-2014, 07:40 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Nothing will happen with extra runs, just more cost, too few runs can do all kinds of damage though...
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 12-03-2014, 07:42 PM
team dc audio
0/11 sssss1268
More the better because you always upgrade eventually so spend the money now so you can spend more later on other stuff
Old 12-03-2014, 07:58 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
To add on, can I do 2 runs of POS and no runs of Neg front to back and then just ground to the frame/metal from the back?
(8) runs 1/0 battery terminals awhitewookie Wiring, Electrical & Other Installation Equipment 6 10-07-2014 05:55 PM
Positive Runs Directly From The Alt Or From Front Battery? BassThrashin General Car Audio Discussion & Questions 15 06-22-2014 11:22 AM
2 runs from alternator to front battery? harveywong General Car Audio Discussion & Questions 6 02-09-2014 06:14 AM
Wiring battery bank from alt or front battery burzendowski General Car Audio Discussion & Questions 9 02-15-2012 04:36 PM
