Stock Subaru Aux - Car Audio Classifieds!
Old 12-04-2014, 10:02 AM
Thelonewolf's Avatar
CACO SLACKER
0/11 ssssss597
Default Stock Subaru Aux
Anyone figure out a way to utilize the Aux in the center console when installing an aftermarket HU?
I have a 2012 Subaru Legacy
http://www.cars101.com/subaru/legacy...onsoleusb1.JPG
Like this... USB is charging only, may try to put my actual usb connection there...
Old 12-04-2014, 10:40 AM
0/11 sssss2011
Feedback Score: 61 reviews
test and tap
Old 12-04-2014, 11:21 AM
CACO SLACKER
0/11 ssssss597
well obviously that would work, I was hoping someone has done this so I know what wires are what...
Old 12-04-2014, 10:08 PM
0/11 sssss2011
lucky for you, i found one of these laying around the shop. they retail for like $15.
AX-SUBUSB-1 [AX-SUBUSB-1] Axxess Integrate, Comprehensive Interface Products
Old 12-05-2014, 06:10 AM
CACO SLACKER
0/11 ssssss597
the usb on mine is just charging. i am looking to retain the aux in.
Old 12-05-2014, 01:15 PM
What does it look like behind the panel and the headunit? I've seen some cars with AUX ports that use a simple 3.5mm connector between the two, meaning you could just use the male end on the other end of the cable to tie into the aftermarket HU AUX port. If it's hardwired, you'll need to trace those wires and determine what is what. There should be three wires for a stereo connection: right audio, left audio, and ground. For a 3.5mm connector those are in a TRS (tip, ring, sleeve) configuration. The tip of the connector is for left, the ring is for right, and the sleeve is ground.
If you remove that panel and can't figure out what wires are for right/left/ground you can build a test rig from a male TRS connector and some wires to check continuity on each wire and match it to either the T, R, or S.
Old 12-08-2014, 06:41 AM
CACO SLACKER
0/11 ssssss597
a 24 pin connector and a 20 pin connector... that is all... having a hard time with steering wheel controls too as the wiring diagrams for my car don't seem to match what is there...
Old 12-08-2014, 10:04 AM
If it uses a proprietary connector on the back you'll need the pin-outs. Perhaps this will help?
Stock head unit information -- pin-outs, aux inputs, and more - NASIOC
You can use a male 3.5mm cable with the wires cut off and stripped to insert that into the stock female jack. Then with the stock (or preferably an aftermarket) harness connected to the back with those wires cut and stripped probe each wire on the male 3.5mm jack plugged into the front, then check each wire on the cur harness on the back for continuity. That will be a bit labor and time intensive though.
Old 12-08-2014, 01:16 PM
CACO SLACKER
0/11 ssssss597
yeah i saw those, they do not apply to my setup, it is different than what i have... i will be mapping them out later today... joy...
02 subaru forester, what to do?? super-rex90 General Car Audio Discussion & Questions 16 12-06-2014 02:34 AM
A little subaru update. silvercookie General Automotive Chat 34 11-21-2012 05:22 AM
subaru justy mcbuggin Competition Corner 0 08-21-2011 12:25 PM
subaru owners HELP? Zooook General Automotive Chat 4 04-08-2011 06:22 AM
subaru is for fags? slamnride Off Topic Chat 5 12-08-2009 11:50 PM
