Tell me about strapping amps. - Car Audio Classifieds!
Old 12-04-2014, 05:41 PM
0/11 ssssss664
Default Tell me about strapping amps.
I've never done it... but considering strapping 2 soundstream rubicon 2500's together to power 2 15's.
Is there any reason why I would want to strap them together at a 2ohm final load vs. running one for each woofer at 1ohm?
I'm assuming the current draw would be less when strapped at 2 vs. independent at 1, eh?
New Jeep. 142db as of now, Details to follow.
Old 12-04-2014, 06:13 PM
tv550's Avatar
0/11 sssss1658
Feedback Score: 37 reviews
I don't see how the draw would be less if they were strapped.
Old 12-04-2014, 06:28 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
Actually running strapped isnt always more efficient. Strapping tends to create more imp rise for some reason. Example i used to run a single Crescendo bc2000d at .5ohm....clamped a solid 1900+rms and some change rising to 1.6ohm at 13v. I decided i was going to try strapping another one and strap at 2ohm (each amp seeing 1ohm) and clamped again to see the power difference thinking i was going to essentially double it....and boy was i wrong. Rising to 3.8ohm still dropping to 13v i clamped a solid 2800rms.....yep a whole 800-900watts difference. So i was actually more efficient with one amp bc i only gained tenths maybe a decibel increase on the meter.
2013 Toyota Highlander
Build to come.....
Old 12-04-2014, 06:46 PM
0/11 ssssss664
Interesting.
I wonder if it has to do with the fact that each amp is only (pretend) 70% efficient on it's own, and (I assume) the multiplication of amplifiers compounds the efficiency ratings.
So say the amp is 70% efficient, but when the signal meets the second amp, you're effectively taking 70% of the first amp's 70% which then equates to 49% efficiency.
I would imagine that having two amps powering each VC independently would be like having two 70% efficient events happening simultaneously, but independently, which results in an overall efficiency of 70% vs. 49%
Drunk thinking / math. Thoughts?
EDIT: Check the math...
Your 1900 wrms amp strapped with another 1900 wrms amp created 2800 wrms.
1900 x .49 = 931.
931 + 1900 = 2831wrms which is almost exactly what you clamped.
Old 12-04-2014, 07:05 PM
0/11 sssss3693
Interesting.
1900 x .49 = 931.
Makes sense to me, what was even better was i sold both my bc2000's and bought my first big boy amp....saz3500v2 and that thing killed my 2-2k amps together. Much more efficient and got a solid 3600rms from one amp. Maybe something to think about down the road. But if you have the 2 amps already, its a pain but gain match them and go with it. Gain matching will be much better than strapping. One per coil like you stated in ur first post.
Build to come.....
Old 12-04-2014, 07:11 PM
0/11 ssssss664
Roger that, I have bi-amped in the past with good results. Just was considering learning a new trick and doing something different. I definitely would like a big single amp like a sundown 3500 or vr4000d but the (watts/dollar) equation doesn't work out in it's favor. Although when you consider the additional money spent to bolster the electrical needed for a less electrically efficient setup, it may just be a wash.
I just want a 150 from an enclosure that's below the window line in my grand cherokee. lol
strapping amps newbasshead General Car Audio Discussion & Questions 8 08-12-2012 12:02 PM
Strapping AQ amps Abcdefranklin General Car Audio Discussion & Questions 20 01-08-2012 01:29 PM
need help strapping amps bottlefed1 General Car Audio Discussion & Questions 1 10-26-2010 09:05 AM
Strapping aq amps resko1 General Car Audio Discussion & Questions 17 01-08-2010 12:56 PM
Strapping amps ??? Rd4me General Car Audio Discussion & Questions 2 12-17-2009 10:01 PM
