How to recone a sub with no dustcap? (ARC Black 12) - Car Audio Classifieds!
Old 12-05-2014, 05:17 PM
0/11 ssssss162
Default How to recone a sub with no dustcap? (ARC Black 12)
How would I go about aligning the coil when the sub doesn't have a removable dustcap? Has anyone reconed a sub like this?
Here are some pics of what im talking about
Old 12-05-2014, 05:21 PM
209native's Avatar
0/11 sssss1975
you got to cut the dust cap off.. my cv's had the same style cap
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
The Following User Says Thank You to 209native For This Useful Post:
iamsonic (12-05-2014)
Old 12-05-2014, 05:22 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
shims on the outside diameter of the coil
similar to this
www.youtube.com/watch?v=JggocgzCe7c
Old 12-05-2014, 06:03 PM
0/11 ssssss162
similar to this
This is what i was looking for, thanks
The only thing im wondering about is there was about half an inch of cardboard-like material between the spider and the basket plate. Is this common? Can i recone it without it? The reason im asking is because i emailed ARC and got most of the specs for the coil and spider size but those measurements included that cardboard "lift".
Old 12-05-2014, 06:07 PM
0/11 ssss31258
nah. that sub has a cap.. it's just set inside the recess of the paper cone
it's the inverted dust cap, happens to be plastic and says arc audio
I have a special knife bent at about 45degrees I use to scoop dustcaps
Old 12-05-2014, 06:14 PM
0/11 ssssss162
ahh i see what you mean
By looking at the pics, is it possible to just glue the spider and coil to underneath the cone in the recess?
This may or may not be a stupid question, ive never done a recone before
Old 12-05-2014, 06:17 PM
0/11 ssss31258
yes but coil wiring connections must be done above the cone below the cap and be glued securely.
Old 12-05-2014, 06:24 PM
0/11 sssss1085
Feedback Score: 23 reviews
You might get lucky and be able to pry that cap off from underneath. I was able to do that with a pair of Boston 12.5 LF's that I reconed and was able to save the original cone and cap.
Just get a small flathead screwdriver and poke it up through the coil opening and pry at the bottom side of the cap's glue joint. You should have enough room to put the screwdriver directly on the glue from underneath.
The Following User Says Thank You to hurrication For This Useful Post:
Old 12-05-2014, 06:31 PM
0/11 ssssss162
could i just drill holes for the tinsel leads through the inside of the recess?
sorta like this
did you heat it with a hair dryer or something beforehand?
Old 12-05-2014, 06:33 PM
209native's Avatar
0/11 sssss1975
I just got home from work and don't see the cv cone and cap anywhere for pics. Like tom said the cap sits down in there I just used a regular utility knife and went slow.
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
6.5'' Black DC Audio Carbon Fiber Dustcap - Pink DC Sticker NoPh33rRaCiNg Speaker Accessories & Parts 10 10-30-2012 10:04 AM
[SOLD] Carbon/Kevlar DC Dustcap (Black and Blue) jonnyv713 Speaker Accessories & Parts 5 04-27-2012 12:19 AM
Can you recone with a Carbon Fiber Cone & CF Dustcap? Jdubs04ss (Fix My Speaker) 15 03-11-2012 10:54 PM
Wtb black dustcap submoofer1 Wanting to Buy (WTB) 6 04-12-2011 09:58 AM
