Amp repair question - Car Audio Classifieds!
Old 08-10-2015, 07:53 PM
mega fatty
0/11 sssss6008
Default Amp repair question
So I have a jbl 6ch in my wife's car
The other day she said it was cutting in and out
I look at it it plays fine
Today I saw it cutting in and out of protect but it's only when the car is running
In auxiliary it works fine
Ch 2 was pulsing + then - dc and protecting.
I took off the speaker (it was blown apparently) and no more dc it works fine
I did not test a different speaker on that ch but it is no longer protecting nor pulsing dc
There is no shorts from checking with my dmm
Anyone seen something like this?
Old 08-10-2015, 08:47 PM
massivespl's Avatar
0/11 sssss8409
Blown speaker causing amp to protect? That's normal if u ask me
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-10-2015, 09:54 PM
mega fatty
0/11 sssss6008
its blown open
no connection
and it only protects when the car is running, if i just turn the accessory on without starting the car the amp worked fine
07 mazdaspeed3
rd d9 @ .5ohm
Old 08-10-2015, 10:30 PM
0/11 sssssss10
Check your volts. Could be a bad alternator regulator.
Old 08-10-2015, 10:48 PM
mega fatty
0/11 sssss6008
Dc was fine and it only measured around .2vac on the dc
It was 12.7 off and 14.2 on
Old 08-11-2015, 12:16 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
I would say something wrong with that particular channel on the amp if all others work fine.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 08-11-2015, 02:29 AM
bassman_soundking's Avatar
0/11 sssss2063
Amp power supple doesnt like higher voltage
I need a H/O alt for my 2006.5 Scion xB
Sold to: Jonesy
Traded with: Jonesy, 310w6, Ciaonzo
Bought from: newtitan. T3audioNavi
amp repair question jb livewire General Car Audio Discussion & Questions 3 11-11-2014 03:58 AM
Amp repair question bluthunder04 General Car Audio Discussion & Questions 5 01-25-2014 07:15 PM
amp repair question shackleford General Car Audio Discussion & Questions 6 11-25-2013 04:37 PM
Amp repair question TWiZTiD859 General Car Audio Discussion & Questions 2 06-11-2011 04:29 AM
Amp Repair question korn4life General Car Audio Discussion & Questions 2 05-07-2010 07:30 PM
