6 layer coil questions - Car Audio Classifieds!
Old 08-11-2015, 08:27 PM
72impala's Avatar
0/11 sssss1706
Feedback Score: 68 reviews
Default 6 layer coil questions
Ok need some people with lots of knowledge or experience on this. Found some nice 6 layer coils that will fit with my MTX9500 motors well. Only thing is, each coil has 2 different impedances, 2 ohm one side, 1 ohm the other. So who in here knows if I can wire these parallel or what weird stuff has to go on with coils like this?
Thanks
2003 6.8L V10 Excursion Limited
2015 MECA STREET 5 WORLD CHAMP
Old 08-11-2015, 08:49 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
As long as they are designed properly so that the individual coils wouldn't fight each other when wired in series or parallel then there shouldn't be any ill effects.
Test each coil with a 12v dc signal and see if the cone moves the same direction both times. If so I'd say you are good to wire them together.
Current Build:
#60sHereIcome
Old 08-11-2015, 09:10 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
you wouldn't need to wire both as parallel or both in series. if ran individual to two different sources, they wouldn't be equal due to the impedance difference. the 6 layer is often done to gain a specific OD on the coil
Old 08-11-2015, 09:23 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Why are they 2 diff impedances?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 08-11-2015, 10:04 PM
Authorized Vendor
0/11 ssss14115
6 layers.
one coil is 4 layers, the other is 2 (down/back winding)
Old 08-11-2015, 10:12 PM
72impala's Avatar
0/11 sssss1706
Why would I have the same coil with 2 different sources? I basically want to wire the pair of speakers down to .75, wondering if it's possible
Old 08-11-2015, 10:29 PM
Authorized Vendor
0/11 ssss14115
you can get 1.5 ohm, .33 or 1.33
Old 08-11-2015, 10:36 PM
72impala's Avatar
0/11 sssss1706
So I cannot wire each to 1.5 and parallel them together for .75? This 6 layer thing is confusing me
Old 08-11-2015, 11:16 PM
Authorized Vendor
0/11 ssss14115
2 ohm in parallel with 1 ohm is .6667.
the 6 layer thing is simple. its just one winding 2 layers longer then the other thus they have different resistance
Old 08-12-2015, 01:13 AM
Souldrop's Avatar
0/11 sssss1270
My only concern is you will have more current going through the lower impedance coil if you run each driver in parallel. I personally would be leery of sending additional heat into the what I'm going to assume is the 2 layer coil. maybe there will be no issues with heat dissipation...Ideally you would run an individual driver's coils in series and then run both drivers in parallel to one another, but that only gets you a final ohm load of 1.5.
2016 Scion iM
- Bone stock for now
4 diameter 4 layer coil/ 8 layer coil. 03navi General Car Audio Discussion & Questions 6 06-04-2014 01:06 AM
4 layer coil in a 8 layer gap.Good or bad idea Groundcontrol General Car Audio Discussion & Questions 7 12-27-2013 01:31 PM
4" D1 8 Layer Coil csweares Wanting to Buy (WTB) 2 04-22-2013 07:55 AM
wtt 2 4 in 8 layer coils for 4 in 4 layer coil marcotheclepto Car Audio Trader (WTT) 8 01-16-2012 08:51 AM
FS: 4 layer 4" coil D2 jonny101abc Speaker Accessories & Parts 25 04-15-2011 12:41 AM
