Pro audio speakers - Car Audio Classifieds!
Old 08-13-2015, 08:37 AM
blkmrideon22s's Avatar
0/11 ssssss487
Default Pro audio speakers
Is it much if I want to run a supertweeters and 6.5 and 8 in each front door or should I do a super tweeter and a single 8 in each door?
1999 mitsubsihi montero sport
1 ct sounds m75.4
2 ct sounds at1400.1
1 ct sounds 6.5 pro audio comp set
Old 08-13-2015, 08:43 AM
massivespl's Avatar
0/11 sssss8409
U can never have to much
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-13-2015, 08:55 AM
0/11 ssssss487
Nice I wanna use a 2 channel amp for my supertweeters and find a 4 channel for the 6.5 and 8's. Is there any other company beside Rockford fosgatr that uses the pass thru technology?
1 ct sounds m75.4
Old 08-13-2015, 11:01 AM
0/11 ssssss584
Larger the diameter the faster it will break up, beam, and roll off. Super tweeters wont reach low enough to cover a 6.5 properly. If you care about that stuff it matters.
If you are the type that only wants loud and don't care if you are missing a few octaves you will be fine
The Following User Says Thank You to DDFusion For This Useful Post:
Souldrop (08-13-2015)
Recommendations for 8" Pro Audio speakers redcon1 General Car Audio Discussion & Questions 13 06-14-2015 10:39 AM
pro audio speakers chevy454 General Car Audio Discussion & Questions 20 10-28-2013 09:08 AM
Thoughts on Pro Audio speakers ENVI3D ONE General Car Audio Discussion & Questions 35 06-28-2013 08:37 AM
Update on pro audio speakers skinneyfinney (Crescendo) 38 05-17-2011 12:06 AM
What are pro audio speakers ^_^ Gem132 General Car Audio Discussion & Questions 30 11-02-2010 12:53 AM
