What Ohm Load Would You Run - Car Audio Classifieds!
Old 08-20-2015, 09:09 PM
0/11 ssssss452
Default What Ohm Load Would You Run
Amp is a Zapco Reference 1100.1. 3 CDT 12" QES-1220 dual 2 ohm sealed box. Would you run 1.34 or 3 ohms? Be nice if an amp repair guy would chime in.
Old 08-20-2015, 10:50 PM
0/11 ssssss165
If the amp is 1ohm stable, I would run the 1.3ohm load.
Old 08-20-2015, 10:55 PM
Super Moderators
0/11 sssss9623
if electrical is stout run 1.3, box rise will help
Old 08-20-2015, 11:00 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7096
A quick google search says it's not
Open Box, Like New - Zapco Reference 1100.1 Monoblock Car Amplifier/Amp (ZAP-1100.1)
The amp does 825 @ 4 and 1100 @ 2 so you'll be in the middle of that at a 3 ohm load, which is about 950 maybe, going into 1500w rms so it should be pretty good if the subs are not crazy under rated.
TLDR the amp does not list 1 ohm stability so run it at 3 ohms.
If it's not enough power then get a [email protected] 1 ohm amp (to accommodate for the extra .3)
team graham
Old 08-20-2015, 11:05 PM
Silver03gt's Avatar
0/11 ssssss687
3 ohms is your only option since the amp is not 1 ohm stable.
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
Old 08-20-2015, 11:59 PM
0/11 ssssss452
I know the amp is 2 ohm stable but seems to be pretty common to run these below 2 ohm on good electrical. I did upgrade the cooling fan and have strong electrical running to it. I think I am gonna run the 1.34 and let you all know what happens with the Zapco. if it survives i'll let yall know so you can try it on your non zapco, JK
Old 08-21-2015, 12:02 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7096
Honestly dude, is it worth the risk? Run at 3 ohm and see how it does. It's likely that it will be good enough for you.
team graham
The Following User Says Thank You to graham For This Useful Post:
macsdad (08-21-2015)
Old 08-21-2015, 12:11 AM
0/11 ssssss452
Well, it was to alotof others. Hers another thing. Its been playing for over n hour on an old $59 CD player, Zapco stouter than that pos? I will report back hopefully in 2 weeks when install is complete. On a side note I never ran (except for box rise) my RF Punchs at 2 ohms, always at 1
Can a amp run below it's rated ohm load before rise. More spl General Car Audio Discussion & Questions 14 02-03-2013 08:59 PM
ohm load burd337 (Sundown Audio) 19 10-17-2012 05:44 AM
What Final Ohm Load Should I run justchill0ut General Car Audio Discussion & Questions 10 09-13-2012 12:17 PM
What ohm load? crownvicon26's General Car Audio Discussion & Questions 10 09-02-2010 12:52 AM
what ohm load would i get? crownvic97 General Car Audio Discussion & Questions 7 07-01-2010 09:24 AM
