Sub not as loud? - Car Audio Classifieds!
Old 08-22-2015, 03:23 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Default Sub not as loud?
Randomly, the sub seems to not be as loud as my front stage today.
I can turn the lc-1 all the way up and it's kinda better...but used to be I didn't need to do that.
What could be going on? Nothing changed. Voltage always 14v
team graham
Old 08-22-2015, 03:32 AM
0/11 ssssss298
Have you checked ground and power wire for bad ground or even burns or bad fuse?
Sent from my draconis using Tapatalk
Old 08-22-2015, 03:34 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
I don't run fuses any more but I will check for burns and things like that.
team graham
Old 08-22-2015, 03:39 AM
0/11 ssssss298
If your having these types of issues and no idea how to fix it then id put some fusing in..
Old 08-22-2015, 03:41 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
I don't see why I would need fuses though. I literally never go under 14v and I know how to properly wire things up.
team graham
Old 08-22-2015, 04:01 AM
You're either getting used to it or there might be a signal voltage problem from whatever your source is. Could be loose RCAs or something.
Old 08-22-2015, 04:30 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
How long does it generally take to get used to the bass? 0% chance the RCA's came loose - they are matching and all very very tight connectors.
team graham
Old 08-22-2015, 06:43 AM
jeffdachef's Avatar
0/11 ssssss440
check for pinched connections. This happened with my RCAs and it limited my output.
Old 08-22-2015, 07:48 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Is it possible that one of the speaker leads that are connected to the speaker terminals inside the enclosure came out and when you hit a bump it loses connection? A friend of mine would lose bass completely when he hit bumps and it turned out the spring was weak in the terminal and the wires came out.
My game is legit,
Old 08-22-2015, 08:46 AM
massivespl's Avatar
0/11 sssss8409
Some days my system seems louder then others. I know if I eat a Vicodin it makes my system sound not as loud. Makes me have like plugged ears so I don't take those for head aches no more because I need my loud boom booms
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Loud?? amurphy1717 General Car Audio Discussion & Questions 32 02-09-2015 06:27 PM
cant get loud! Ryan1126 General Car Audio Discussion & Questions 16 08-11-2012 03:47 AM
Help me get loud? KTMrida4life General Car Audio Discussion & Questions 14 03-06-2012 11:33 AM
Would this be AS loud? milly General Car Audio Discussion & Questions 16 10-04-2011 09:27 PM
