My first big "from scratch" build is underway... need some advice - Car Audio Classifieds!
Old 08-22-2015, 08:10 AM
0/11 sssssss60
Default My first big "from scratch" build is underway... need some advice
I got two questions and an idea that could be idiotic or genius, I have no idea. Some relevant links first:
I'm building my first custom sub from the ground up, using this motor.
The specs for the OEM voice coil for that motor is here.
The OEM VC is a perfectly fine VC, but using parts that were made to fit together ruins all the fun. Here's the voice coil I plan on using.
So, question #1: Can I use the fancy PSI voice coil with this motor? Because if I do, there's going to be a sizable gap between the pole piece and the voice coil, and idk if that makes a difference. Even more worrying, there would only be a hundredth of an inch clearance between the voice coil and the top plate on either side, and I don't know how wide the tolerances are with this sort of thing. I also don't know if I can center the VC that accurately using only playing cards/index cards/whatever I have lying around at the time. Is it doable, or are my concerns well-founded?
Question #1.5: Say I can't use that voice coil, do you guys know of any suppliers of quality voice coils besides PSI/fixmyspeaker?
Question #2: I wasn't sure on what height my voice coil should be when I get around to gluing everything in, so I searched around a bit, and found exactly 2 relevant results. Both said the center of the voice coil should be level with the center of the top plate. Is that a rule I should follow, or is it bullshit? Because I'm not willing to risk like 120$ on what two dudes said 6 years ago on a forum I don't recognize.
Finally, and this has nothing to do with the stuff above, I was thinking recently about how to improve voice coil cooling. I only recently found out that people are using ferrofluid to improve cooling. Now, the issue with that is ferrofluid was never meant to act as a medium to transfer heat between two surfaces, nor was it meant to withstand high temperatures. I mean, I haven't read the msds in a while, but I'm pretty sure ferrofluid is just some ferromagnetic dust suspended in water, which evaporates eventually.
No, what you need is something designed for that. Like Arctic Silver, or whatever your favorite thermal compound is. Just a tissue-thin layer is all it takes. Friction is the most obvious issue, yes. But don't underestimate the power of even an entry-level subwoofer. For example, I ran the numbers on an RF P3D4 and found that it produced a whopping 56 pounds of peak force. So maybe a little friction won't make much of a difference.
Tags
building, custom, questions, recone, voice coil
Planning out my first big build... Need advice!!! BlueXI General Car Audio Discussion & Questions 63 06-03-2015 08:22 PM
Wanting to get out of "mainstream" brands but need advice Texaslegend903 General Car Audio Discussion & Questions 56 06-07-2012 12:29 PM
My friend's daughter is 15 but acts like she's "mature", any advice for them? Wingman0121 Off Topic Chat 69 05-03-2012 12:42 PM
MONSTER 18" sub BUILD MTX 9500 4" VC my first build XORstatus Build Logs 113 04-16-2012 07:42 PM
BUILD LOG Explorer limo 6 IB3s walled 300 cubic feet 50"x12"x3.5" port 15Hz tune kryptonitewhite Build Logs 121 01-31-2011 12:57 PM
