Aero Port help - Car Audio Classifieds!
Old 08-24-2015, 10:07 AM
Thelonewolf's Avatar
CACO SLACKER
0/11 ssssss597
Default Aero Port help
Ok so my brain is ready to explode...
I know i need 8-12 square inches of port area per cube. I will be running about 5 cubes gross with an ethos 18 running saz 1500.1d v2...
planning on using an 8 inch sonotube and probably make a fiberglass flare on the baffle end. Needs to be 25.25 long according to most calculators...
Does that sound right? i know it is around 50 square inches of port, any tips for the flare, should i bother? will there be a lot of port noise without the flare?
HELP! lol
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
"Puny god" - The Hulk
Old 08-24-2015, 10:20 AM
0/11 sssss2649
This is what I use.
Products Menu
Sounds like you're wanting to use an 8" port.
Edit: you shouldn't have any issues with port noise. use the calculated to figure out port length for your desired tuning. Don't forget to add the volume of port.
Old 08-24-2015, 10:25 AM
CACO SLACKER
0/11 ssssss597
that is the one i am using to get 25.25"
Old 08-24-2015, 10:34 AM
CACO SLACKER
0/11 ssssss597
should i bother with a flare? will it matter if i do a flare on the baffle side and not the internal?
Old 08-24-2015, 10:43 AM
SWIFT's Avatar
0/11 ssssss656
The Ethos like alot of port area. If it were a slot port you would want around 100sq in for an 18. Not sure what that translates to with an aero port......
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
Old 08-24-2015, 10:39 PM
With rise you might barely pull 1kw from that amp on really dynamic peaks. You'll be fine with a single 8". You will not need to flare it unless you want to play around with it a bit and try to gain a little on the meter.
Old 08-25-2015, 01:45 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
If you have to choose... The inner flare is more important.
All subs like a lot of port area. Lol.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 08-25-2015, 03:54 AM
Agreed. Even a small baffle to give the open port end a flush surface is good (plus it helps brace the port).
Old 08-25-2015, 06:11 AM
CACO SLACKER
0/11 ssssss597
great thanks! not going for meter just want it to sound good
Old 08-26-2015, 06:51 AM
CACO SLACKER
0/11 ssssss597
so i will plan on making an internal flare of some sort thanks! if i will only be pulling maybe barely 1kw should i get a different amp?
slot port or aero port tommytee General Car Audio Discussion & Questions 3 08-07-2011 09:17 PM
finding 10" aero port, port calculation help darkkon General Car Audio Discussion & Questions 6 07-24-2011 07:26 PM
