Small removable build. Definitely need some help - Car Audio Classifieds!
Old 08-24-2015, 06:43 PM
doug118's Avatar
0/11 sssss4674
Default Small removable build. Definitely need some help
I'm in the middle of building a race car but of course it has to have a nice audio setup in it to overcome the noise of the exhaust when I drive it. I'm thinking either 2 8's or 2 shallow 10's. Only looking to do 1-1.5 cubes on 1000 watts
Now here's my biggest dilemma. Check out this sweet ass hump on the middle of the cargo area. That hump is only 6" from the rear hatch so I have to work around that. What would you guys do?
(NOT MY ACTUAL CAR)
Old 08-24-2015, 06:49 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Glass the bottom to the shape of the floor
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 08-24-2015, 07:05 PM
doug118's Avatar
0/11 sssss4674
I was thinking about glassing it but that's the last thing I want to do. Once I lay out the battery and nitrous bottle locations, I'll get a better idea as to how much room I have left without glassing anything.
I also thought about doing a sealed setup but I've never ventured down that road and not sure if going from my truck to a small sealed setup would be satisfying at all
Old 08-24-2015, 07:18 PM
massivespl's Avatar
0/11 sssss8409
Two sundown E 8s in a ported box with a 1,000watt amp mounted to it. Could fit in There and just pull it out when ur gunna race.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-24-2015, 07:28 PM
doug118's Avatar
0/11 sssss4674
It'll either be sa-8's or sd10's. Maybe some Crossfire 8's if I can find them. But yeah that's the plan to mount the sub amp to the box. 4 channel will just be mounted to the back seat. Also have to make some kind of nice neat distribution point for amps and relays. I'm used to running everything off the battery or busbars so this is a whole new ballgame for me
Old 08-24-2015, 08:28 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
As Tfade suggested the glassing, more so just the bottom would net the best space and make removal and replacement easy plus lighter when lifting out.
The learning curve of fiberglass is rewarding.
Old 08-25-2015, 02:59 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Incorporate the amp(s) within that unusual space with lexan see thru's and build a nice ported box atop of it. Having the lexan with removeable bolts/t-nuts for easy amp accessability.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 08-25-2015, 06:45 AM
coolhandluke's Avatar
0/11 sssssss55
Well what kinda hot rod ya building?Love a fast car.
Old 08-25-2015, 08:16 AM
doug118's Avatar
0/11 sssss4674
Just a little turbo awd 4 cylinder. Makes roughly 400awhp now but 700awhp is in the works now
Old 08-25-2015, 10:03 AM
0/11 sssss2011
Feedback Score: 61 reviews
why not cut it out than weld a flat piece in it's place?
Small Bedroom build BKNIGHTS General Home Audio/Video 3 07-22-2014 03:29 PM
small re-build BallzFast Miscellaneous Build Logs 1 04-15-2013 09:54 AM
small SQ build rdlyn13000 (Sundown Audio) 2 01-07-2013 05:17 PM
Small Boombox Build 813thumper Miscellaneous Build Logs 2 02-04-2012 11:09 PM
Small bass package for power wheels build or small daily setup jjffy6 Car Audio Packages 10 10-10-2011 12:08 PM
