30hz lpf on mono amp? - Car Audio Classifieds!
Old 08-24-2015, 08:45 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7099
Default 30hz lpf on mono amp?
Who goes down this low?
I hear voices in the sub too often...wondering if I should consider amps that have a lower lpf.
EDIT: My amp apparently has 30hz but I still hear voices and anything about 41hz just sounds like crap...
team graham
Old 08-24-2015, 08:51 PM
0/11 sssss3526
What is your box tuned at?
Old 08-24-2015, 08:53 PM
massivespl's Avatar
0/11 sssss8409
Did u buy a real HU yet with sub out?
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-24-2015, 08:57 PM
0/11 sssss3526
Ya I'm not sure why youd set lpf @30, even sloped, that's going to eliminate a fair amount of output. I usually set mine around 55hz. Tuned at 30, I have the bandwidth I prefer
Old 08-24-2015, 09:02 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7099
32hz
yeah but too lazy to install one. Would it matter if I use a line driver with it?
Cause anything above 40hz just resonates the cabin and I've killed a few subs playing above 40hz. Luckily they were under best buy warranty.
team graham
Old 08-24-2015, 09:14 PM
0/11 sssss1070
i dont understand how you're hearing your vocals through your subs with the lpf that low... i set mine pretty high(80hz) and i dont hear any vocals. it sounds like an issue with something providing the signal? i have seperate sub pre outs.
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Sounds like your midbass is severly lacking if you are hearing voice from your sub. If I turn off my flutes 70-500 HZ, maybe I could hear it but I know I def can't any other way.
Do you have like 0dB or 70Hz and up until you hit the PA mids? Maybe that is why you even notice it?
I have a PPI DSP so I can turn channels off to tune, but what are you listening to that it presents this problem?
Last edited by craiggus365; 08-24-2015 at 09:16 PM. Reason: missed an 'r' added dB
Old 08-24-2015, 09:39 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7099
I don't know either.
I mean when I turn the front stage off because I can't tell if it's my car rattling or something is wrong with the sub. Isn't it bad to play that high on a sub?
team graham
Old 08-24-2015, 09:45 PM
Partially Unwound
0/11 sssss2697
A filter has a gradual roll off so you will hear some frequencies above the xover point no matter what you do.
You could run a sub with out a LP filter, it would not hurt anything except ears potentially. You will get port resonance up high that sounds nasty but the inductance of the sub will naturally roll it off at some point, just higher than optimal.
The Following User Says Thank You to craiggus365 For This Useful Post:
SPLEclipse (08-25-2015)
Old 08-24-2015, 11:05 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
You guys are high or something.
Those aren't voices from his subs.....rather in his head.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
For Sale: 4 SA-12 D4's & Birch Box @ 30Hz PHATBOi 12" Subwoofers 14 06-04-2014 07:23 PM
Sundown amp owners..wheres you lpf set to? rocksolid84 (Sundown Audio) 12 03-07-2014 07:50 PM
WTB 1k mono amp and 1500-2k mono amp KTMrida4life Wanting to Buy (WTB) 19 10-17-2012 11:39 PM
Sundown Amp LPF setting SKDooley General Car Audio Discussion & Questions 6 12-19-2010 07:22 AM
