2002 pontiac aztek problem with am radio hook up - Car Audio Classifieds!
Old 08-25-2015, 06:07 PM
0/11 ssssss313
Default 2002 pontiac aztek problem with am radio hook up
is there a complete wiring diagram? i cant find the remote wire
Old 08-25-2015, 07:30 PM
0/11 ssssss313
also it says the yellow wire is accessory switch but then in the speaker wires it says yellow is for Left Rear Speaker Negative Wire (-):
2003 Pontiac Aztek Car Audio Wiring Diagram
Old 08-25-2015, 07:37 PM
Silver03gt's Avatar
0/11 ssssss687
Most of the time your neg speaker wire will have a strip in it. Do you have a yellow stripped wire?
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
Old 08-25-2015, 08:23 PM
0/11 ssssss313
i have one yellow on the factory harness but on the diagram it shows yellow as both accessory switch and Left Rear Speaker Negative also theres 3 or 4 extra wires
Old 08-26-2015, 10:04 AM
0/11 ssssss313
really need some help with this my subs are sitting in my room **** teasin
Old 08-26-2015, 11:49 AM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2081
Feedback Score: 32 reviews
Odd.
Are there two yellow wires?
If yes, then the yellow wire next to a dark blue wire and a brown wire is the speaker left rear negative and the yellow wire next to an orange wire and a black wire is your switched twelve volt positive.
This should be comfirmed with a digital multimeter before you wire anything up.
If this doesn't work, then you have to use another switched source from elsewhere.
You might have GM's data bus, or something ruther, system with does not have a 12 volt switch, if I remember correctly.
If I were gay I would marry you.
Funny how a girl stops talking to you when you say you would rather be homeless and give her nothing than have a kid...women...
Old 08-26-2015, 02:02 PM
0/11 ssssss313
just one that i seen but im goin to triple check when i get home
Old 08-26-2015, 02:29 PM
0/11 ssssss313
just 1
Old 08-26-2015, 04:19 PM
0/11 sssss2081
What color are the wires next to it?
It's prolley a speaker wire. You gots the danged data bus system if i'm not mistaken.
In other words, you don't have a switched wire, sorry bud.
You technically do, but it never shuts off all the way and it is not a full 12 volts. IIRC, its like 6~7 volts.
Old 08-26-2015, 04:31 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Run a wire to an acc in the car fuse panel
240a High Output Alty - Cobalts, Pontiac G5, Pontiac Persuit BassAddictJ Wiring, Electrical & Other Installation Equipment 7 01-04-2016 04:47 PM
2004 Pontiac Sunfire Wiring harness Problem josh09 General Car Audio Discussion & Questions 8 12-18-2013 03:45 PM
? can u hook speakers 2 radio & 2 amp off same radio? damon_dice_hkbang General Car Audio Discussion & Questions 10 05-03-2012 12:25 PM
hook subs up to stock radio using RCAs? joshua Off Topic Chat 4 12-06-2010 10:13 PM
2002 Pontiac Bonneville mattj General Car Audio Discussion & Questions 1 05-27-2010 09:37 AM
