Output transistor mosfet FDA24N40F - Car Audio Classifieds!
Old 08-25-2015, 07:01 PM
0/11 sssssss36
Default Output transistor mosfet FDA24N40F
Im looking for two fets to replace two Fairchild
1D14AN
FDA
24N40f
I have found a few with the same series number(24n40f) but they have different numbers on the first line. Does that matter? Are there any replacements that are compatible? They came out an ab vlf 500.1
Thanks!!!!
Old 08-25-2015, 08:09 PM
Pioneer621's Avatar
0/11 ssssss494
The only important number is the main part number FDA24N40F; the other numbers (top line) is the batch / date codes and not important while sourcing replacements.
However, you do need to install all matching MOSFETs per bank (all must have the same batch / date code).
Typically if only one or two FET's are blown you replace ALL of them, even if the output stage uses 16. You can sometimes get away with replacing all of them in one bank and leaving the rest alone, but I feel more confident replacing them ALL and is what I do. Don't skimp or it's gonna blow again and will be a crappy repair.
Also do NOT buy them on ebay or any other non reputable part distributor (a lot of fake / counterfeit parts on there), the price seems cheap, but when the amp goes up in smoke again and takes out the power supply FET's you'll be sorry you went the cheap route!
You can't go wrong with Mouser or Digikey:
Mouser has them in stock: http://www.mouser.com/ProductDetail/...G%2FX4wA%3D%3D
Don't forget to check the gate resistors as they often open up when FETs blow, and the drivers; you miss something there and it may blow as soon as you power it up, you may already know all this, but since your asking about FET's you may not...
Good luck!
The Following User Says Thank You to Pioneer621 For This Useful Post:
Silver03gt (08-25-2015)
Old 08-25-2015, 09:10 PM
0/11 sssssss36
okay cool thanks so much for the help, i cant wait to get it back up and running
Looking for transistor clip bars for RF Punch 200x2 Chipper Wanting to Buy (WTB) 1 07-30-2015 12:08 AM
Transistor, MOSFET & capacitor checker NIB ghostmechanic Miscellaneous Stuff For Sale 6 12-09-2011 09:53 PM
Transistor clamps for an Orion HCCA250/Extreme 800 ghostmechanic Wanting to Buy (WTB) 6 09-20-2011 07:40 AM
Transistor Tape.. I got a quote on it.. iamsonic Off Topic Chat 5 05-22-2009 10:59 AM
mosfet question MC AUDIO General Car Audio Discussion & Questions 13 02-15-2009 01:52 PM
