Blazers with multiple alts. - Car Audio Classifieds!
Old 09-04-2015, 11:14 AM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default Blazers with multiple alts.
Wheres my blazer guys with multiple alt setups? Putting a dual alt kit on my buddies blazer and was just wanting to get opinions on what brands and modifications had to be done to get them to fit. I've already talked to JZ designz and his kit looks good. Gonna be dual 350 amp alts.
Old 09-04-2015, 11:36 AM
tacomaguy1's Avatar
0/11 sssss4401
had 3 on mine...270's, one in the ac spot was a hairpin
the dual side used the bracket from JZ designs (I think)
Was kind of hard finding a belt with the weird sized pulleys i used but once I did it was a solid setup
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 09-04-2015, 11:56 AM
massivespl's Avatar
0/11 sssss8409
Yea my buddy has dual alts on his an s10 with alt in the AC spot
http://youtu.be/DHGQyPvhfEY
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-04-2015, 12:05 PM
0/11 sssss6030
That looks like the same bracket from JZ designz. Any mods you had to do?
Old 09-04-2015, 12:56 PM
tacomaguy1's Avatar
0/11 sssss4401
the throttle cable bracket had to be unbolted and moved up out of the way, can see it resting on the back of the right alt. Also had to bend the oil dipstick tube back a bit
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 09-04-2015, 01:14 PM
0/11 sssss6030
Gotcha, shouldn't be bad.
Old 09-06-2015, 08:10 AM
0/11 ssssss198
Iraggi has a nice dual setup for 4.3s
Old 09-06-2015, 11:28 AM
0/11 ssssss296
For older blazers or newer, my alt is on the driverside.
Old 09-07-2015, 02:25 AM
0/11 ssssss198
Passenger side is what I have seen from him. It was around 750 for 2 alts and the bracket. He custom makes then so I think he could easily make it work for the newer style blazer
Can you have multiple tuning frequencies by using multiple different-length ports? Wingman0121 General Car Audio Discussion & Questions 17 10-30-2012 12:11 AM
Wiring multiple alts 03tbls General Car Audio Discussion & Questions 6 10-14-2012 10:40 PM
Multiple alts on jeep Team Nemesis-Jared General Car Audio Discussion & Questions 2 08-06-2011 09:56 PM
multiple alts Gabriel ruiz General Car Audio Discussion & Questions 0 04-12-2011 09:34 PM
Question for anyone running multiple alts. GM 5.3, AD244. TREETOP General Car Audio Discussion & Questions 3 11-30-2010 04:40 PM
