2 12" RPL or 1 15" CPM x2 15"?? - Car Audio Classifieds!
Old 09-04-2015, 01:28 PM
bassman_soundking's Avatar
0/11 sssss2063
Default 2 12" RPL or 1 15" CPM x2 15"??
As the title asks, will my Single eD SPV.3 AKA Crystal Mobile Sounds CMP x2 15" be a better daily choice, or My Pair of SoundSplinter RLP 12"s
I know there is a slight cone area advantage to the pair of 12s, but there is xmax advantage the eD/Crystal, as well as more coil area I believe.
SS RLP specs:
Dual 4 Ohm Measurements
Qts: 0.207 Qts: 0.219 Mounting Depth: 17.5 cm
Qes: 0.226 Qes: 0.242 Total Depth: 18.5 cm
Qms: 2.470 Qms: 2.266 Outside Diameter: 31.8 cm
Fs: 23.43 Hz Fs: 18.856 Hz Weight: 35 lbs
Re: 3.7 Ohm Re: 6.26 Ohm Magnet Width: 18.8 cm
Ls: 4.060 mH Ls: 7.382 mH Mounting Cutout: 28 cm
Rp: 7.478 Rp: 14.68 Displacement: 0.15 cu ft
Vas: 87.73 L Vas: 142.7 L
Mms: 177.9 g Mms: 168.8 g
Cms: 259.2 u Cms: 421.9 u
Bl: 20.70 T*m Bl: 22.74 T*m
SPL: 88.81 dB SPL: 87.79 dB
Sd: 0.0471 m^2 Sd: 0.0471 m^2
Xmax: 24.2 mm Xmax: 24.2 mm
CMP x2 15 specs:
Fs 23.5 Hz
QMs 7.33
VAS 4.2 cu ft / 119 Liters
CMs .123 mm / N
MMd 12.7 oz / 360 Grams
Xmax 1.10 in / 28 mm
Qes .56
Re 2.0 Ohms
Z 2.0 Ohms
BL 14.0 Telsa / M
Power Handling 1600 Watts RMS
Qts .52
SPL 92.2 dB
Voice Coil Diameter 3.0"
Displacement .3 cu ft
Mounting Depth 7 3/8"
Fs 23.5 Hz
QMs 7.33
CMs .123 mm / N
Qes .56
Re 2.0 Ohms
Z 2.0 Ohms
BL 14.0 Telsa / M
Qts .52
SPL 92.2 dB
The 15" is D2, and the SS are D4, so final load will be the same, or close.
I am running on Autotek MM4000.1D
RMS @4 Ohms is 2500+, since this amp makes it rated power @2 ohms bridged Mono.
I need a H/O alt for my 2006.5 Scion xB
Sold to: Jonesy
Traded with: Jonesy, 310w6, Ciaonzo
Bought from: newtitan. T3audioNavi
Old 09-04-2015, 02:17 PM
0/11 ssssss543
12's that single 15 wouldn't be a thought.
Old 09-04-2015, 04:25 PM
0/11 sssss2063
I will eventually put both my 15s in there, but right now I dont have space or the electrical to handle my amp at 2 ohms.
I just want sure the lil more cone area would justify making a new box.
Sold to: Jonesy
Old 09-04-2015, 05:26 PM
209native's Avatar
0/11 sssss1975
I say the 12s the rlp 12s are nice subs. I have a oem rlp 12 myself and its a damn nice sub
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 09-04-2015, 06:02 PM
0/11 sssss2063
Mine are oem as well.
They have oxidized cones, and kinda loose spiders now though.
Sold to: Jonesy
Old 09-04-2015, 06:31 PM
209native's Avatar
0/11 sssss1975
Just means you can turn the gain down a little
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 09-04-2015, 06:36 PM
0/11 sssss2063
I was thinking bass might not be as tight for rock music?
What size enclosure and port area do you think I need?
Sold to: Jonesy
Old 09-04-2015, 06:39 PM
209native's Avatar
0/11 sssss1975
Mine is a bit loose as well my box started around 2 1/4 and I think I ended up at 1 1/2 or so as for the port i don't even remember what I tuned to...lol
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 09-04-2015, 06:42 PM
0/11 sssss2063
Do you have the D4 or D2?
Seems specs are a lil different.
I had tried one in 2.75 box I had my 3 hp in and it was a lil sloppy sounding and peaky aroun tuning.
I can get away with a smaller box for the pair than I have on the single 15 then...nice
Sold to: Jonesy
Old 09-08-2015, 03:30 PM
209native's Avatar
0/11 sssss1975
mine is a d4 and like I had mentioned I didn't like it in the big box it sounds way better imo in the smaller box. back from vaca sorry for the way late reply.
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Car Audio Bracelets!! "Bass Head" on front and "Im louder than you!" on back. g6ryder Miscellaneous Stuff For Sale 138 04-22-2013 05:27 PM
[SOLD]2 Digital Designs 9510 "F"'s with G Parts CF Dual 1.4 aluminum "Z" coils. JustinWhitty 10" Subwoofers 15 07-01-2011 07:13 AM
Mid/Tweeter "cups"/"covers"/"enclosure"/"etc"??? oxsign General Car Audio Discussion & Questions 11 04-21-2010 04:29 PM
