2005 f-150 audio build help - Car Audio Classifieds!
Old 09-05-2015, 07:23 PM
0/11 ssssssss9
Default 2005 f-150 audio build help
GREAT forum guys, after extensive reading and reading i finally narrowed it down the choices to build my audio system
polk audio db6501 or the mm6501 componemts with the coax in the rear with a rockford prime r400x4
what do you guys think about those choices? mms or dbs? rf r400x4 good? any other choices i should be looking?
as for subs is between sundown 2 sd3 10s or 2 skar vd 10 with a rockford forget prime 1200x1 not sure about that amp though incase you guys recommend something else, is there a big difference bettween sd3 10 and sa 10?
never heard either of these speaker so am going by from what i read, i live in a tiny island off of puerto rico so don't have car audio places to check out... any help will be greatly appreciated thanks for all the good info..
Old 09-05-2015, 07:37 PM
massivespl's Avatar
0/11 sssss8409
db and mm both are nice.
A Rf 400x4 will do. Bigger the 4ch the better of u want loud!
The ad is a shallow mount woofer
The Sa is a beast 2.5" coil woofer
And I'm not one for puttin speakers in back doors. Take those speakers and get pods for up front in the kick. Get that sound up front
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-05-2015, 07:49 PM
0/11 ssssssss9
will i be better of getting the sa10s instead of the sd3? and try to build a box for them,
Old 09-05-2015, 07:50 PM
massivespl's Avatar
0/11 sssss8409
As long as u have the room yes get the SA
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
2005 G35 coupe SQ Build BigSix Build Logs 8 06-05-2014 09:52 AM
Build in progress 2005 Trailblazer LT bizzy07 Build Logs 3 08-16-2012 03:33 AM
2005 Lexus GS Economy Build Scott P Build Logs 13 12-09-2010 07:51 AM
2005 F-150 Exhaust mods 92K1500 General Automotive Chat 45 04-13-2010 10:52 PM
