problems after installing aftermarket radio - Car Audio Classifieds!
Old 09-09-2015, 01:57 PM
0/11 ssssss313
Default problems after installing aftermarket radio
i recently installed a new radio (without a harness) (spliced) and now my door bells, windshield wipers, power windows & speedometer lights wont work.. i have a couple theory's first is theres extra wires from the cars original harness that have nothing to plug into
orange
black & white
blue
purple
grey
second the extra wires were just taped up do they need to be grounded?
2002 pontiac aztek
pioneer deh-1300mp
please help me figure this out
Old 09-09-2015, 01:59 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
You likely blew a fuse.
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 09-09-2015, 02:02 PM
Team SPL Farms
0/11 sssss5000
2002 Pontiac Aztek | Stereo Wiring Diagram
And wired wrong. According to this
Kenwood ddx470
The Following User Says Thank You to Todd Dupler For This Useful Post:
iamsonic (09-16-2015)
Old 09-09-2015, 02:03 PM
0/11 ssssss313
fuses were the first thing i checked
Old 09-09-2015, 02:47 PM
mega fatty
0/11 sssss6008
Did you connect illumination or dimmer?
That may not blow a fuse but could make it not work if it's not the correct polarity
Old 09-09-2015, 02:50 PM
0/11 ssssss313
i dont think i did
Old 09-09-2015, 04:24 PM
0/11 ssssss313
im ordering a replacement harness an getting one for the radio hopefully it works
Old 09-09-2015, 04:30 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Most GM vehicles require the can-bus box to keep everything working correctly.
That particular model, I believe, has more in the radio than just the radio.
If you check metra they prob could help you.
Metra Online
The Following User Says Thank You to craiggus365 For This Useful Post:
Maniac (09-09-2015)
Old 09-09-2015, 04:37 PM
mega fatty
0/11 sssss6008
that metra site said you need the can module.
you can go with iirc 70-2003, you just have to wire the acc wire from your power window wire in the driver kick panel. that will retain the power until door is opened, but you wont have door chims. eveything else will work, unless you fried something
07 mazdaspeed3
rd d9 @ .5ohm
The Following User Says Thank You to tymoto21 For This Useful Post:
Maniac (09-09-2015)
Old 09-09-2015, 05:52 PM
0/11 ssssss313
will these work? what exactly do i need to keep everything working like door chimes
Metra 70-2003 Wiring Harness for Select 1998-2009 GMC Vehicles
http://www.amazon.com/Metra-TurboWir.../dp/B0002BEVMK
Help with aftermarket radio with factory amp. Souldrop General Car Audio Discussion & Questions 10 04-12-2014 08:24 AM
When using a aftermarket eq do I still need to have settings on my radio Mnorwood01 General Car Audio Discussion & Questions 0 12-19-2012 07:40 PM
Cheap aftermarket JVC radio Racerkid15 Head Units, Processors & EQs 5 05-13-2012 02:16 PM
1997 Silverado: installing aftermarket tweeters in stock location rugerjitsu General Car Audio Discussion & Questions 3 04-09-2011 07:11 PM
87 taurus aftermarket radio - no sound westman995 General Car Audio Discussion & Questions 3 11-03-2010 12:07 PM
