HCCA 5000.1d - Car Audio Classifieds!
Old 09-10-2015, 09:58 AM
Blackone1125's Avatar
0/11 ssssss107
Default HCCA 5000.1d
Guys,
Any input would be greatly appreciated. Thinking about purchasing this amp to run two HCCA 12.4's and was wondering whether this seems legit? Here are the power ratings (pulled from the website):
RMS WATTS @ 4 OHM at 12.6V 2,120
RMS WATTS @ 2 OHM at 12.6V 3,600
RMS WATTS @ 1 OHM at 12.6V 5,480
TOTAL POWER WATTS 11,000
Anyone with any real world experience with this amp on here? Results? Thanks.
1998 BMW 540i
Headunit: Stock DSP; Hifonics MX-1
Front Stage: Cerwin Vega 5.25's
Rear Stage: OEM 5.25's
Sub: RE Audio SX 10.4
Amps: Rockford 400.4 & bd1000
Old 09-10-2015, 10:22 AM
0/11 ssssss535
I ran one for couple weeks while my m4b was being fixed. Never clamped it but it was .5db louder than my m4b (which does 5k). The HCCA amp runs really, really hot though.
The Following User Says Thank You to chance_p For This Useful Post:
Blackone1125 (09-10-2015)
Old 09-10-2015, 11:06 AM
0/11 ssssss107
Thanks for your response. What kind of electrical are you using? That's a big concern for me as well.
1998 BMW 540i
Old 09-10-2015, 11:09 AM
0/11 ssssss535
Well I was wired to 2 ohm. I did a 150.0 on the windshield with the hcca 5k and 2 ethos 18s. Electrical consisted on factory alt, mechman 320 alt, and 1 105ah battery under hood. 2 runs ofc straight into the amp
0/11 ssssss584
Keep in mind Orion is now owned by the same disturber for pyramid.
The Following User Says Thank You to DDFusion For This Useful Post:
Old 09-10-2015, 11:11 AM
0/11 ssssss535
Keep in mind DDfusion has no first hand experience with this amp and takes every opportunity to shit on anything not DD.
Probably just upset that I gave a fair direct comparison of a 900 dollar amp to a 1400 dollar DD amp and the DD amp wasn't as loud.
The Following 4 Users Say Thank You to chance_p For This Useful Post:
corrie3232 (09-11-2015), e46inperrycounty (09-11-2015), IS300IAdeathRow (09-10-2015), mitchell0715 (09-10-2015)
Old 09-10-2015, 11:23 AM
0/11 ssssss584
I didn't say it was bad.. Judging by its price and the name on it, I take your gain to user error. Orion has NEVER been cheap even when Directed owned them.
I'm not shitting on anything, just making a very valid point. If it upsets you go get on your moms tit
Old 09-10-2015, 02:41 PM
Biggcaddi's Avatar
0/11 sssssss59
Hey man i have much respect for the HCCA line but if your electrical isnt up to standards for that amp it will automatically go into a low wattage output mode and it will be very noticeble with the bass. A few years ago i was running 2 HCCA12.2s on 2 HCCA D5000.1, 2 runs of 1/0awg 2 Kinetik 2400s and 1 Kinetic 1800, 300a alt, my voltage dropped to about 12.8v at the lowest and both amps would give out the lower wattage output everytime the voltage went below 13v. It was frustrating because the subs wanted the power everytime! I personally would not recommend that amp unless your electrical is very very solid. Most amps run good on the voltage i had without any problems. While i was upgrading to my current system i had the chance to put my DC 10k on the 12.2s and i gained a whole new respect for the subs and the HCCA line. I never did clamp the amps so not sure what the output was. I was hitting [email protected] on dash sealed. Box was subs up port back tuned to 30hz in a 99escalade.
Old 09-10-2015, 04:08 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
This sounds like a typical DD huggers response...."I take your gain to user error" lol dont be upset that something in this world performed better than the almighty DD equipment. But when doing a direct swap out of one thing to another and you yield better results....in this case maybe its better will i sound like a hugger of Sundown if i said i lost db when going from my saz3500v2 to my DD m4? Same sub, same box, same electrical, same damn sub
2013 Toyota Highlander
Build to come.....
Old 09-11-2015, 06:50 AM
0/11 ssssss584
Don't get ticked at me for posting this.
Think about it. When has the HCCA amp not been the most expensive big amps?
Now they got bought out by Pryamid and all of a sudden the ratings are pretty unrealistic and the prices are less then the cheapest Koreans.
Does that not scream BS to you?
looking for orion hcca component speakers and an orion hcca 2500.1 new style amp michael559 Wanting to Buy (WTB) 0 04-10-2012 12:00 PM
soundigital 5000.1 bigbass100db Mono Amplifiers 7 03-30-2012 09:41 AM
Orion Hcca 2100 comp, (2) Orion Hcca 225 digital captnfangdango CACO Amp Internals 7 08-31-2011 12:03 AM
HCCA or T2?? (WTB HCCA) volsfan92 General Car Audio Discussion & Questions 42 08-14-2010 12:57 AM
5000 dak446 Uncensored Off Topic 35 01-31-2010 05:52 PM
